Kenne Bell Boost a Pump users....
Old Jun 30, 2004 | 10:09 AM
Phil97SVT's Avatar
Phil97SVT
Default Kenne Bell Boost a Pump users....
What % increase are you using?
Phillip
Old Jul 4, 2004 | 09:06 PM
Dr. Dan's Avatar
Dr. Dan
Default Re: Kenne Bell Boost a Pump users.... (Phil97SVT)
Phillip
Phil,
Sorry it took so long to respond...Vacation.
Anyway, the folks at LPE said to cut off the reostat and solder the wire so that when the pump comes on at 3lbs of boost, the pump runs wide open. Several sources at the time said that it was OK to do that. Cleaner install that way. So far, so good.
Old Jul 5, 2004 | 10:08 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
100%
VR
Old Jul 5, 2004 | 10:23 AM
rwj383's Avatar
rwj383
Phil;
you ever take pics of your new fuel system setup? I'd like to see how you have everything under hood as well as back at the driver tank for the external return line. thanks!
Robert
http://www.gen3motorsports.com
Old Jul 5, 2004 | 10:38 AM
SideStep's Avatar
SideStep
Default Re: Kenne Bell Boost a Pump users.... (vetterdstr)
100%
VR
Same here, but I don't have to....
Old Jul 5, 2004 | 10:50 AM
vetterdstr's Avatar
vetterdstr
Default Re: Kenne Bell Boost a Pump users.... (SideStep)
after all the time and money spent on this new engine and S/C setup, 100% feels about right.
VR
Old Jul 5, 2004 | 03:33 PM
blu00rdstr's Avatar
blu00rdstr
I had it tuned at 75%.
If it's a hot day or I hear any ping, I crank it to 100%.
To Kenne Bell Boost a Pump users....
