I vaguely remember that when the 02 Z06 came out with the 405 ponies, we discussed and discovered that to achieve the specs of the LS6 cam if you were to swap it into an LS1 or 01 LS6, you need to change the ENTIRE valvetrain, i.e. cam, pushrods (I thought they were a little longer??) rockers and valves??
am i smokin crack or is this the case???
reason I ask is that I am dropping a 6.0 liter long block (milled heads .030) with LS6 cam, and the 5.3 liter intake and accessories
I am thinkin I will have a bout a 400 hp set up (CR will be a little lower at 10:1 instead of 10.5:1 in the LS6) with the additional cubes and the long tube headers that I got from TByrne !!!
Re: 02 up LS6 cam and valvetrain geometry?? (Ram Air Tony)
I am going through this now and this is what I have uncovered. The LS1 block was used from 97 to 00, and the LS6 block was used thereafter. The cam journals are the same size and distance but the cam base circle of the LS6 was reduced in size to achieve higher lift without enlarging the journal bores in the block. In doing so, GM lengthend the valves on the LS6 by .6mm or 6mm to keep the geometry correct. If you are putting LS6 heads and valves on an LS1 and keeping the LS1 cam base circle you should change the pushrods to 7.350" length. In your case I don't know what your pushrod length should be, but you can measure it, or hopefully someone on the forum has done your build and will give you the lengths.
The cam base circle is the 'imaginary' circle the lobes are ground to. In other words, if you put the cam in a lathe and ground a lobe so it was perfectly round without taking off any material on the back of the lobe and measured that, you would have your base circle. I read an article recently, but don't have it. It gave the measurements of the LS1 cam, the 01 LS6, and the 02+ LS6 cams. Not sure if that would help you, but you can get a pushrod length checker from Comp Cams, check your length after the engine is put together, and the can make you a set of custom length pushrods to accomodate any valvetrain geometry.
I believe there is a tech article on the Comp Cams website that details how to measure the pushrod length for ideal geometry. It's pretty easy and the tool is only about $20.
Re: 02 up LS6 cam and valvetrain geometry?? (ArKay99)
Re: 02 up LS6 cam and valvetrain geometry?? (2KREDVert)
I am thinking about the Z06 cam too for my 2000 LS1. Has anyone on this forum done this so we don't have to reinvent the wheel?
Why not get a cam with similar characteristics but on an LS1 base circle? Then you won't have to change anything except the springs and pushrods, but the pushrods can be stock length = 7.400". I'd suggest going a little bigger than LS6 specs if you are going to go through all that work. If you are not going to put on LS6 heads you won't see 405hp, more like 370. While you are at it, if you don't have an LS6 manifold on there you should change that too. The LS1 manifold will hold back power on a larger cam. Just my $.02
Re: 02 up LS6 cam and valvetrain geometry?? (Ranger)
The valves on the '02 and later Z06 are .100 longer than other Ls1 motors. The valves are hollow stem NaK filled valves. The base circle of a cam is the part of the cam the lifter rides on when the vlaves are closed. Think of this as the smallest part of the cam. If there was no lobe on the cam, you would be left with just the base circle. A cam can only have x ammount of lift beecause of the limitation of the size of the cam bore. So, when you get to a certain point the only way to increase lobe lift is to shrink the original base circle. You can use a Z06 cam with stock heavy valves or aftermarket stainless valves. You simply need to compensate for the decrease in base circle and the shorter valves with a differnet pushrod and a better spring (like a 918).
You'll be fine in a 6.0L with this combo. But if you want low end grunt, there may be some other cams that might do better. Look in the truck section on LS1tech.
screw the hi jack......i am all game for listenin
RAT
Ok. Hope you don't mind this. I am installing 2002 Z06 heads w/stock valves, Comp 918 springs, Thunder Racing 7.400 pushrods, LS1 stock rockers and lifters, LS1 head gaskets, (slightly thinner), Thunder Racing 224/224 .563/563 @112lsa cam in a 99 LS1 block. All I've read points me to using the 7.350" pushrods, but Paul at TR told I would be fine with the 7.400 so that is what I am going to do. I will have more preload on the valves with this. Does this mean the valves will stay open longer? If so, is this a good thing?
OK, research has been done, thanks for the LS1 Tech posts JRod !!
6.0L is same block as all LS motors (basically, iron, but still same) ..... will my MILLING the heads down .030" affect geometry or will the lifters soak that up???
I am feeling better by the day now (about this swap )
According to this Hib Halverson article: http://www.idavette.net/hib/02ls6/page2.htm
the LS1 cam has a base circle of 19.7 mm and the 2002 LS6 cam has a base circle of 19mm. That is a difference of .7 mm, which converts to just under 0.028 inches (0.02757999).
If you are going to be milling the heads 0.030 then you would only be increasing the preload by less than 0.002 if you use LS1 valves instead of LS6 valves. That is something that the stock lifters can surely absorb without problems.
The only question I can see is will the heavier LS1 valves be too much for the LS6 springs? All I can say is that I have heard of a number of budget conscious f-body people that have used the LS6 cam and springs with LS1 valves without problems
