Active handling problem
Old Jun 30, 2004 | 10:43 AM
SJ6295's Avatar
SJ6295
6th Gear
Default Active handling problem
Has anyone had a problem with the active handling system in a 2001? I am getting a service vehicle soon error and a service active handling soon error.
Old Jun 30, 2004 | 11:07 AM
Jim 47's Avatar
Jim 47
Default Re: Active handling problem (SJ6295)
do you have any codes??? If so, let us know what they are and that will lead you to the problem.
Jim
Old Jun 30, 2004 | 06:23 PM
SJ6295's Avatar
SJ6295
6th Gear
Default Re: Active handling problem (Jim 47)
I get a history code only. And it is not on the list of codes I have. C1288 in the TCS module. The odd thing is that the traction control still works even after the error occurs.
Old Jun 30, 2004 | 10:05 PM
Bill Dearborn's Avatar
Bill Dearborn
I am reading from my 97 manual but yours should be very similar. That code is for the steering position sensor. When this code is current the Magnasteer is disabled which means the steering should be harder. ABS/TC remain active with this code.
By the way it means the system can't figure out exactly where the steering is pointed so Active Handling can't be activated.
Bill
[Modified by Bill Dearborn, 10:07 PM 6/30/2004]
Old Jul 2, 2004 | 05:17 PM
SilvaDragon's Avatar
SilvaDragon
Default Re: Active handling problem (Bill Dearborn)
I had this problem with my '99. It was the steering position sensor at the base
of the steering column.
If you decide to tackle this yourself, I found that there is enough play in the
wires connected to the column that they don't need to be disconnected
(which is good since you don't mess with the airbag wiring).
The hardest part is the U-joint on the steering shaft in the engine compartment,
which is a pain due to its location.
Old Jul 3, 2004 | 03:21 AM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
Default Re: Active handling problem (SilvaDragon)
speed sensor on the wheel is staying open just needs replacement
Old Jul 3, 2004 | 06:17 AM
02c5Ls1's Avatar
02c5Ls1
yeah i had that same problem however it seems to go away and come back when least expected however havn't had a problem since...also when u park the car is it on a level surface.....
To Active handling problem
