Oil Pressure Range for 6-Speed
Old Jun 30, 2004 | 06:12 PM
mfh4's Avatar
mfh4
Default Need Advice on Oil Pressure Range for LS1 6-Speed
Can anyone tell me what the oil pressure range should read on the DIC for a C5 (2000) six-speed. I see that on the DIC it may range from high 30's to low 50's in correlation with the RPMs. Is this normal or should it be more constant. Thanks. New C5 owner, so hope this isn't an old issue that's been answered a hundred times before.
MFH4
[Modified by mfh4, 7:31 PM 6/30/2004]
Old Jun 30, 2004 | 08:25 PM
jerrymcb's Avatar
jerrymcb
Default Re: Need Advice on Oil Pressure Range for LS1 6-Speed (mfh4)
Normal.
Old Jun 30, 2004 | 09:00 PM
Richin Chicago's Avatar
Richin Chicago
MFH4
Quite normal. Mine runs about 40 psi at 1700 RPM with 210 deg oil.
Old Jun 30, 2004 | 09:19 PM
mfh4's Avatar
mfh4
Thanks guys. Much appreciated.
Old Jul 1, 2004 | 07:14 AM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
I have a Y2K, MN6, I used to worry about the oil pressure gauge because it used to bounce around from 30 to 60 PSI. And as a matter of fact , it still does. As long as it doesnt read 0 or 80, im happy. I did have it re-ringed this year with 12500 miles because of excess oil usage. I oil pressure gauge acted the same before and after the re-ring
To Oil Pressure Range for 6-Speed
