problem putting cheapy plugs in my c5 for some testing?
Old Jul 3, 2004 | 05:50 PM
T_Vert's Avatar
T_Vert
Default problem putting cheapy plugs in my c5 for some testing?
i want to see if my plugs are giving me problems. They sell a BOSCH-SUPER that is .99 and they say its for the vette. I want to throw them in do some cyl. misfire testing then maybe take it to the track. I have an ever so slightly rough idle and i dont recall if i had it stock. Im wondering if maybe my mech cracked a plug when he did my clutch and pulled the header off. he seems like a very careless person IMO. Anyone know the resistance of the stock wires?
dave
Old Jul 3, 2004 | 06:55 PM
Richin Chicago's Avatar
Richin Chicago
Default Re: problem putting cheapy plugs in my c5 for some testing? (TT_Vert)
dave
The stock wires should not exceed 700 OHMS. Most I have seen are in the 300 OHM range.
The Bosch plugs Bosch shows for the C5 are:
HR8DPX PLATINUM PLUG Gap=.060
4305 PLATINUM2 Do not Gap
4458 PLATINUM+4 Do not Gap
4205 PLATINUM PART Gap=.060
Old Jul 3, 2004 | 07:02 PM
leaftye's Avatar
leaftye
Default Re: problem putting cheapy plugs in my c5 for some testing? (Richin Chicago)
The cheapo copper plugs are very likely to perform better than the platinums in terms of power, smoothness, and fuel efficiency, if you use the right temp plugs. I've heard WAY more bad things about platinum plugs than good. Sure they don't corrode, and if cleaned periodically, could have a 100,000 mile service life, but notice that I said if cleaned periodically. Since any plug will get dirty over time, to keep it performing well you'll have to take them out occasionally. If you're doing platinum to avoid maintenance, I'm afraid you're wasting your money. I've accepted that my plugs are going to come out occasionally, and only moved away from copper when I heard Iridium plugs can provide more spark and also more corrosion resistantance.
Anyway, about Platinum, do a search and you'll find some stories about people pulling their plugs only to find that some of the tips were missing!
Old Jul 3, 2004 | 07:07 PM
T_Vert's Avatar
T_Vert
this is the list I have from autozones site, is it wrong?: see any problems using these cheapies?
BOSCH-PLATINUM_2
DO NOT REGAP 4305 $3.99
BOSCH-PLATINUM 4205 $1.99
BOSCH-SUPER 7571 $0.99
AC-DELCO_RAPIDFIRE 12 $4.19
AC-DELCO
CAN ALSO BE USED 41-932 $5.99
AC-DELCO
DOUBLE PLATINUM 41-952 $5.99
SPLITFIRE
SPLIT "V" DESIGN SF10E6 $4.49
CHAMPION 13 $1.69
GAP AT .050 (IN THOUSANDTH OF AN INCH)
CHAMPION_DOUBLE_PLAT 7013 $4.49
CAN ALSO BE USED 7983 $4.49
DENSO
IRIDIUM PLUG 5325#4 $12.99
DENSO
PLATINUM PLUG 5070 $5.99
AUTOLITE_DOUBLE_PLAT APP5243 0 YR
Old Jul 3, 2004 | 07:10 PM
T_Vert's Avatar
T_Vert
so do you think the 99 cent ones will suffice for now?maybe a few track passes to test some stuff? i know in my old blower mustangs i used the cheapy autolite 24s w/ nary a problem ever/
Dave
Old Jul 3, 2004 | 07:15 PM
Richin Chicago
Dave
As long as the heat range is correct I can't imagine you will have a problem. Just double check to make sure the replacement plug is the same length from the thread seat to the tip.
Old Jul 3, 2004 | 07:22 PM
T_Vert's Avatar
T_Vert
will do, they list em as OEM replacement so im sure they are ok.
Dave
Old Jul 3, 2004 | 07:34 PM
FixedRoof's Avatar
FixedRoof
Cruise-In VI Veteran
Used those Bosch cheapo's in my old LT1 Camaro. Made a major difference over worn out stockers. Ran smooth with em.
Old Jul 3, 2004 | 08:31 PM
T_Vert's Avatar
T_Vert
Default Re: problem putting cheapy plugs in my c5 for some testing? (Steve92LT1)
all wires ohmed out ok at 360-365 ohms. The nice suprise was finding 2 denso iridium plugs and 6 ac delco plugs in my car. They all look good, but they are being swapped for some testing.
Dave
Old Jul 3, 2004 | 08:36 PM
Richin Chicago
Dave
If they are original you may have been one that got plugs during the Delco strike. Do they appear to be identical except for the logo?
Old Jul 3, 2004 | 09:07 PM
T_Vert's Avatar
T_Vert
ill have to look at em a bit closer later on.
Dave
Old Jul 4, 2004 | 07:14 PM
myblackC5's Avatar
myblackC5
you might want to look for exhaust leak.............that will cause a miss, ruff idle. he did take the header off? did he put in new gaskets? start the engine up get it hot. turn it off, wait till the next morning then go around and tighten all the nuts.
Old Jul 4, 2004 | 09:31 PM
T_Vert's Avatar
T_Vert
he took the header off but didnt use a new gasket. THe gaskets are a spring steel i dont know if that'd be a problem. i dont hear or see any exhaust leaks though
dave
To problem putting cheapy plugs in my c5 for some testing?
