Bouncing right headlamp
Old Jul 3, 2004 | 09:57 PM
turboo2u's Avatar
turboo2u
Default Bouncing right headlamp
When my headlamps are up (at night) and I hit some kind of bump, the right headlamp bounces for a fraction of a second, causing the light given off to bonce with it. Nothing major but kind of distracting. Any adjustment for this? Thanx!
Old Jul 3, 2004 | 11:59 PM
BQuicksilver's Avatar
BQuicksilver
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Bouncing right headlamp (turboo2u)
Not that I can think of. Do you have the stock plastic lens? I went to the glass euro lens and it got worse. It never bothered me any before that...I did get used to it.
Old Jul 4, 2004 | 07:22 AM
turboo2u's Avatar
turboo2u
Default Re: Bouncing right headlamp (BQuicksilver)
So I guess I'm not only one.
Old Jul 4, 2004 | 08:35 AM
chasswartz's Avatar
chasswartz
mine did this also, the dealer said this was normal. i took the headlamp assembly apart and bent the 2 stops slightly to take out the play. these are the metal tabs with a white plastic cover. you may need to adjust headlight aim after doing this.
Old Jul 4, 2004 | 11:34 AM
warpster's Avatar
warpster
Default Re: Bouncing right headlamp (chasswartz)
I had this same issue when I went to the T84 housing! I've learned to live with it also.
chasswartz....could you post some pictures of what you are adjusting?
Old Jul 5, 2004 | 08:31 AM
chasswartz's Avatar
chasswartz
i don't know to post pictures. i will e-mail to warpster. i think you could do this without taking anything apart, i took it apart to see how it worked
To Bouncing right headlamp
