Fuel System Upgrade?
Old Jul 4, 2004 | 04:07 PM
EFI-1's Avatar
EFI-1
Default Fuel System Upgrade?
Aloha all, I am about to order the i/c Mag for my 2003 Z06. In doing some research I found out that the mid 2002 and newer C5/Z06's came with a fuel system that is possibly much more difficult (or maybe impossible) to upgrade. I am really hoping to find out that I will not need to run a Kenne Bell Boost-A-Pump. So who has the 411 on the fuel system and whaty available upgrades are there for me?
Thanks in advance! Dave
Old Jul 4, 2004 | 07:50 PM
EFI-1's Avatar
EFI-1
Default Re: Fuel System Upgrade? (EFI-1)
TTT
Old Jul 4, 2004 | 08:15 PM
kumar75150's Avatar
kumar75150
Depends on what 21st century recommends.
I know many people with over 500rwhp NA using the sotck fuel system with just injectors.
On s/c applications, I see some using the Racentronix setup or boost a pump. I'm not sure if they are being extra cautious or not.
Old Jul 4, 2004 | 08:25 PM
EFI-1's Avatar
EFI-1
Default Re: Fuel System Upgrade? (kumar75150)
Yep it's the actual pump issue that is worrying me.....I'm not particularly fond of the KB Boost A Pump. I'm hoping I'll be able to fuly upgrade the pump.
Old Jul 4, 2004 | 08:50 PM
Dr. Dan's Avatar
Dr. Dan
Check your build sheet for "FFS" fuel system. That is the one that cannot be upgraded at the time, no one was aware of this. An easier way is to pull the Passenger side rear tire and see if there is an access panel partially hidden by the wheel well. Should be just above the area of the caliper on the frame. If you see it, then you have the dreaded FFS system. The upgraded pump (I'm assuming Magnuson) in the kit will not fit. Had the same prob. Went with KB, LPE recommended. So far so good.
Old Jul 4, 2004 | 09:36 PM
kumar75150's Avatar
kumar75150
Default Re: Fuel System Upgrade? (Dr. Dan)
The Racetronix setup is apparently good for 600rwhp.
I was in a similar situation with my nitrous but I am thinking about doing a stand alone system for the nitrous.
Old Jul 4, 2004 | 10:44 PM
EFI-1's Avatar
EFI-1
Thanks guys. Yes, it's the i/c Mag I'm planning on. WayneE at z06vette.com was mentioning that he is running only larger injectors and has had no problems in the mid 500HP range......I'm crossing my fingers!
[Modified by EFI-1, 5:45 PM 7/4/2004]
Old Jul 5, 2004 | 03:01 AM
kumar75150's Avatar
kumar75150
you really shouldnt have any problems IMO
I have seen 480-550rwhp with 30# SVO injectors and stock fuel pump on TONS of cars.
Old Jul 6, 2004 | 02:51 PM
BHP's Avatar
BHP
MAG tells me that the new kits will use their custom BAP. You don't want to even try to put a fuel pump in the FFS tanks.
Old Jul 7, 2004 | 03:19 AM
EFI-1's Avatar
EFI-1
Default Re: Fuel System Upgrade? (BHP)
LOL, that's what I heard.....
Old Jul 9, 2004 | 09:42 AM
Racetronix's Avatar
Racetronix
Supporting Vendor
Drop the inspection cover underneath your gas tank (two bolts).
If the sending unit is visible from the back of the tank (yellow connector) then you are in luck. The current Racetronix system will work for you.
If not then the new upcoming Racetronix system will be available in a apx. 1-2 months.
Old Jul 9, 2004 | 01:25 PM
EFI-1's Avatar
EFI-1
Good input. Great news. Thanks for the info Racetronix!
To Fuel System Upgrade?
