A4 ATF fluid ?
Old Jul 5, 2004 | 08:38 PM
Ls1Rat's Avatar
Ls1Rat
Default A4 ATF fluid ?
I've been hearing conflicting opinions.
So Redline is not a good choice ?
Old Jul 5, 2004 | 08:41 PM
Laguna Blu's Avatar
Laguna Blu
Default Re: A4 ATF fluid ? (Ls1Rat)
Redline D4-ATF is doing just fine for me. Never had any tranny problems (knock on wood) while pushing close to 400 RWHP and 407 RWTQ. I do change the fluid and filter once a year which is probably overkill but is peace of mind for me.
Old Jul 6, 2004 | 06:48 AM
IMQUIK's Avatar
IMQUIK
Old Jul 6, 2004 | 10:38 AM
Ls1Rat's Avatar
Ls1Rat
Default Re: A4 ATF fluid ? (Pewtavert)
I'd think that it's good medicine
Old Jul 7, 2004 | 10:10 AM
Ls1Rat's Avatar
Ls1Rat
Any other opinions ?
Old Jul 7, 2004 | 11:08 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
AMSOIL ATF. My stock tranny now has 15k street miles, 7 DE days, and 20 SCCA races and counting...
All below from the AMSOIL ATF Product Description page:
"Improves fuel efficiency, reduces transmission temperatures and increases transmission life. Provides unsurpassed thermal stability and up to five times the service life of conventional ATFs. Delivers maximum protection for towing and other severe-duty applications. Product Code: ATF
Recommended for applications requiring the following specifications:
GM; Dexron II, Dexron III (GM 6297M, 6417M)
Ford; Mercon, Mercon V
Chrysler; ATF+ through ATF+4
Allison; C-3 & C-4
Caterpillar; TO-2 & TO-3
Voith G1363
ZF; TW-ML-14C
Honda; Z-1
Mitsubishi Diamond SP II & III
GM Strasbourg (European Imports) and Opel
Toyota; Type T and T-IV
Vickers I 286S & M2950S
PRODUCT DESCRIPTION
AMSOIL Synthetic Automatic Transmission Fluid exceeds the performance requirements for domestic and foreign automatic transmission fluid applications. AMSOIL ATF provides automatic transmissions, power steering units and hydraulic equipment with excellent lubricating protection and better performance over a wider temperature range than do conventional petroleum fluids.
Resists Oxidation and Thermal Degradation
AMSOIL ATF resists thermal and oxidative degradation up to three to five times longer than conventional transmission fluids do. It protects clutches, planetary gears, valves, pumps and seals from damaging sludge and varnish deposits. AMSOIL ATF helps prevent component overheating and ensures cooler, smoother transmission operation.
Provides Low Temperature Protection
AMSOIL ATF outperforms petroleum fluids in low temperature fluidity. In fact, AMSOIL ATF offers three times the cold temperature fluidity required by current automatic transmission fluid specifications. AMSOIL ATF provides easier starting, faster warm-ups, smoother shifting and improved fuel economy.
Anti-Wear Protection
AMSOIL ATF provides smooth shifting and long, trouble-free transmission life. In addition, the anti-wear additive package makes AMSOIL ATF an excellent lubricant in other hydraulic systems. In tests designed to measure wear characteristics under severe service and high pressure operating conditions, AMSOIL ATF far exceeds the requirements of hydraulic equipment manufacturers.
Extended Drain Intervals
AMSOIL ATF is formulated for extended drain intervals. Transmissions usually operate under severe service conditions. They are subjected to extensive idling, frequent short trips, cold temperature driving, sustained hot weather driving or trailer towing. When conventional transmission fluid is used, it should be changed every 15,000 to 30,000 miles. AMSOIL ATF should be changed at intervals up to three times longer than the recommendations of the vehicle manufacturer.
APPLICATIONS
AMSOIL Synthetics Automatic Transmission Fluid is completely compatible with other synthetic and petroleum automatic transmission fluids. AMSOIL ATF is a universal, multifunctional fluid and greatly reduces the need for specialized fluid inventories and the possibilities of misapplication.
SERVICE LIFE
AMSOIL ATF has an expected fluid life of three times the automatic transmission manufacturer's recommendations. Drain intervals may be extended indefinitely when fluid analysis is used.
TYPICAL TECHNICAL PROPERTIES
AMSOIL 100% Synthetic Automatic Transmission Fluid (ATF)
Kinematic Viscosity @ 100°C, cSt (ASTM D-445)
7.5
Kinematic Viscosity @ 40°C, cSt (ASTM D-445)
36.0
Viscosity Index (ASTM D-2270)
182
Noack Volatility, % weight loss (DIN 51581) 10.8
Flash Point °C (°F) (ASTM D 92) 222 (432)
Pour Point °C (°F) (ASTM D 97)
-56 (-69)
Four Ball Wear Test (ASTM D 4172B: 40 kg, 75°C, 1200 rpm, 1 hour, Scar in mm) 0.40
Brookfield Viscosity (cP) -10°C = 465
Brookfield Viscosity (cP) -20°C = 1030
Brookfield Viscosity (cP) -30°C = 2505
Brookfield Viscosity (cP) -40°C = 7150
Old Jul 8, 2004 | 01:29 AM
BHP's Avatar
BHP
Rat FWIW: Talk to the folks who know trannies, like Chuck at FLP. Use only dino DexIII. Never had a problem but have seen many early trans failures with synthetics. Check this link for more opinions: http://www.ls1tech.com/forums/forumd...0&daysprune=-1
To A4 ATF fluid ?
