ZO6 anti-sway bar
Old Jul 6, 2004 | 01:37 PM
billiardcue's Avatar
billiardcue
Default ZO6 anti-sway bar
Installed a ZO6 front anti-sway bar on my 04 Z51 vert, what a difference.
It flattened out the ride with out adding harshness, best $81 spent so far.
I live on top of a mountain, shortest route to the bottom is 1 1/4 miles with 12 turns, Vette driver's paradise.
Old Jul 6, 2004 | 02:19 PM
N8's Avatar
N8
Default Re: ZO6 anti-sway bar (billiardcue)
Wher did you get them for $81?
Old Jul 6, 2004 | 03:58 PM
allanlaw's Avatar
allanlaw
Default Re: ZO6 anti-sway bar (N8)
Price is right, all he needed to replace was front bar and 2 bushings since he had the '04 Z51 to start with. Try any of the supporting GM parts folks on the Forum.
Old Jul 6, 2004 | 04:07 PM
billiardcue
Fitchner Chevrolet, have made several purchases from them, excellent to deal with and good prices.
Old Jul 6, 2004 | 04:55 PM
Boo383's Avatar
Boo383
I have an 01 Mag red coupe with Z51 so I assume my rear sway bar is the same as a ZO6 rear sway bar. At just $81 this will probably be my next upgrade! Thanks for sharing!
Old Jul 6, 2004 | 08:35 PM
George8211's Avatar
George8211
Default Re: ZO6 anti-sway bar (Boo383)
It's a great upgrade, I am very pleased with my front sway and 04 shocks on my 1999 Coupe.
By the way.... I love the picture.... I to need to move to the mountains
[Modified by George8211, 8:36 PM 7/6/2004]
Old Jul 7, 2004 | 01:41 AM
MUKAK's Avatar
MUKAK
Default Re: ZO6 anti-sway bar (George8211)
Get T1 bars u will b IMPRESSED
Old Jul 7, 2004 | 06:22 AM
CAJUNY2KC5's Avatar
CAJUNY2KC5
I've got Hotchkis F/R added to my Z51. What a BLAST
Old Jul 7, 2004 | 08:14 AM
leaftye's Avatar
leaftye
Default Re: ZO6 anti-sway bar (MUKAKsC5)
I wouldn't get T1 bars unless stickier tires are installed up front. The T1 bars will introduce understeer, and stickier tires up front are needed to counter the effect. Many of the guys racing with T1 bars run the same width tires up front as they do in the back.
Old Jul 14, 2004 | 08:56 PM
IM QUIKR's Avatar
IM QUIKR
I just installed the Z06 sway bars on my '99 coupe and it sits like ghetto cruisernow, way up high. Why would this happen? They don't support the static weight of the car, do they? I drove around the block and cornered hard to set the springs but it still sits too high. What gives?
Old Jul 15, 2004 | 01:29 AM
leaftye's Avatar
leaftye
Did you tighten the clamps down real tight, even torqued to spec? If you did, it's really too tight. The sway bar should be able to swing freely if the endlinks are detached. What you may do to get proper torque and function is to place a washer between the clamp and the suspension cradle/carriage. Even then, the shocks can take a while to settle.
> Eugene
Old Jul 15, 2004 | 02:21 AM
USA-VET's Avatar
USA-VET
what is the proper torque?
Old Jul 15, 2004 | 05:51 AM
patmo's Avatar
patmo
I did the full z06 suspension swap on my 2002 a4 vert w/fe1 suspension and I say the zo6 suspension(fe4) is what should be on all vettes. It handles so well and is not harsh at all. Also it is easy to do. I would say this is one of the most overlooked and best bang for the buck upgrades!
Old Jul 15, 2004 | 08:24 AM
CAJUNY2KC5's Avatar
CAJUNY2KC5
Me too - I'm looking for the torque settings, too..
Old Jul 15, 2004 | 08:35 AM
IM QUIKR's Avatar
IM QUIKR
End link = 53lbft
front bushing mount = 43lbft
rear bushing upper = 49lbft
rear bushing lower = 70lbft
Old Jul 15, 2004 | 08:43 AM
CAJUNY2KC5's Avatar
CAJUNY2KC5
Originally Posted by drcoffee
End link = 53lbft
Thanks much!!! Will those settings work on other than stock, too?
Old Jul 15, 2004 | 11:39 AM
powderski13's Avatar
powderski13
I did the same for my 02 vert..Z51 springs, Z06 sway bars, Bilstein Sport shocks, chromie Z06 wheels and Michelin Plot Sports. Lowered about 1 inch with Z06 alignment specs. Comfortable and handles like it is on rails :flag
To ZO6 anti-sway bar
Old Jul 15, 2004 | 12:55 PM
jawski's Avatar
jawski
It'll take a few miles for the suspension to settle whenever the car is jacked.
Old Jul 15, 2004 | 01:02 PM
MTV's Avatar
MTV
St. Jude Donor '03-'04-'05
Originally Posted by leaftye
Did you tighten the clamps down real tight, even torqued to spec? If you did, it's really too tight. The sway bar should be able to swing freely if the endlinks are detached. What you may do to get proper torque and function is to place a washer between the clamp and the suspension cradle/carriage. Even then, the shocks can take a while to settle.> Eugene
Are you talking about torquing the bushing clamp bolts or end link nuts? Best,
mtv
Old Jul 15, 2004 | 05:56 PM
leaftye's Avatar
leaftye
The torque for the brackets is still to tight for any sway bars from base to T1. To get the right spec and proper fit, put a washer in there as a spacer. Just remember that with the endlinks detached, the swaybar should swing FREELY. If it doesn't, thing it's just more friction in the suspension, and friction is the enemy of good handling.
> Eugene
