Help w codes please
Old Jul 8, 2004 | 09:31 AM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
Default Help w codes please
I'll try and keep this short..last year my dash lit up the Svc Actv handl/ABS/Traction Cntrl..took it to the stealership (still under warranty) and they fixed it,,said it was ABS modulator valve,,fine,,now this morning (about a year later) same display,,so when I got to work I scrolled through the diagnostics and got this:
28TCS- 2 codes c1225-h
c12283-h
everything else clear but to other history codes which were;
U1064-h
B2203-h
I started the car again 2 times and drove around, then shut it off and cranked again and no display on the dash came up....all clear..and no difference in performance...I am thinking maybe I just hit a bad bump or maybe with a lot humidity lately it's triggering this??? I am not a tech wizz by any means so I am interested to hear feedback.
Thanks!
Old Jul 8, 2004 | 09:37 AM
Automag928's Avatar
Automag928
Thoser are all history codes, nothing with a "C" at the end to signify current trouble.
Old Jul 8, 2004 | 09:41 AM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
Automag thanks for your reply...I was thinking the same. I want to avoid going to the dealer if at all possible
Old Jul 8, 2004 | 09:59 AM
Automag928's Avatar
Automag928
If you look in the tech tips section, there are some helpful links as well... Go here, then scroll down to the word doc with all the codes. Then you can at least see what the history codes were -- https://www.corvetteforum.com/techti...D=26&TopicID=1
Old Jul 8, 2004 | 10:16 AM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
Hey thanks alot! I was looking for this link earlier and could not find it. I now have it saved.
To Help w codes please
