Difference In Tuners
Old Jul 9, 2004 | 08:15 PM
97vettec5's Avatar
97vettec5
Default Difference In Tuners
I was wanting to learn how to tune my car on my own. But was wondering why most people just don't buy a tuner and do it themselves. Is it possible to buy a tuner and basically teach yourself how to do it all? Any help or any ideas would be great. Also, if you can, what tuners would be best to use.... Predator, LS1Edit, etc.?
Old Jul 9, 2004 | 08:38 PM
Mike Mercury's Avatar
Mike Mercury
you might try looking in the "C5 Scan and Tune" section of this forum.
Old Jul 9, 2004 | 11:34 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Hp Tuners and LS1Edit are currently available as far as actual Editors go. With these you can make changes to various tables in the PCM. Soon EFILive Flash/Scan will be available.
You will need a scanner to monitor parameters ( Timing,RPM, MAP. Fuel Trims etc.) Autotap, Ease and EFILive are available as stand alone scanners. HP Tuners includes a scanner with their Editor. Most of us Prefer EFILive's Scanner.
Check out the "Scan and Tune" section regularly and the "PCM and Diagnostics" section on LS1Tech.com.
Here's a link to a decent thread on Tuning info ->http://www.ls1tech.com/forums/showthread.php?t=124186
Good Luck.
To Difference In Tuners
