Need Help With Diff Leak Problem!!
Old Jul 11, 2004 | 09:37 PM
Vegas Vette's Avatar
Vegas Vette
Default Need Help With Diff Leak Problem!!
My 2000 Coupe has a a leak on the drivers side diff cover. My warranty is up so I have to make the repair my slef. Well this is where I'm at everything is off and I'm down to the diff cover. Note the diff is still in the car there is a stud that goes into the trany and the cover "WTF" how do you get the stud out to get the cover off. You dont have to much room in that area to work with. Has anyone done this repair befor any tips for a first timer....
Old Jul 11, 2004 | 11:01 PM
Vegas Vette
TIT ANYONE!!! I need some advice.
Old Jul 12, 2004 | 01:42 AM
Dope's Avatar
Dope
Resident moron
Got any pics? The only stud in the area I can think of, is the one at the bottom of the tranny. There's a nut on the diff side of it. I'm pretty sure that doesn't affect the cover though...
That nut is a pain anyway. 15mm gear wrench helps.
Dope
Old Jul 12, 2004 | 03:21 AM
Vegas Vette
I can take a pic for you to look at the stud goes thru to the diff cover into the tranny there is one on each side of the diff in each cover it has to be removed to get the cover off to replace the o ring in there. So I'm not sure how to get it out.
Old Jul 12, 2004 | 03:36 AM
Dope's Avatar
Dope
Resident moron
If you've pulled all of the bolts, and you remove the nut from the stud, can you just pull the cover out sideways?
Dope
Old Jul 12, 2004 | 01:16 PM
Vegas Vette
Thanks for the advice Dope I will have to work on it to see what I can do with it. If anyone wants to chime in on this topic please do so I could use all the help I can get.
Old Jul 12, 2004 | 03:48 PM
chasswartz's Avatar
chasswartz
put 2nuts on the stud, lock them together, and remove the stud
To Need Help With Diff Leak Problem!!
