AC air diverter door issue
Old Jul 14, 2004 | 09:24 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Default AC air diverter door issue
Had a problem a few weeks ago with the AC condensor drain being clogged and leaking water into the cabin. I have fixed that issue, but the air diverter door (controled by vacuum) doesn't work. I flip it to dash only, I still get air in the middle vents and floor. So I am unable to concentrate any air where it is really needed. Plus it doesn't seem to blow hard enough (blower motor windings have some rust)
Any suggestions on where to start for the air diverter door?
Old Jul 14, 2004 | 10:52 PM
LoneStarFRC's Avatar
LoneStarFRC
Have you ever had any battery related (as in leaking) issues? Not only is the computer directly below the battery, but there are also a couple of the nylon vacuum lines and a vacuum accmulator right in this area as well. Many have experienced the leaking battery acid which can (and in some cases did) eat through the vacuum line(s) causing erratic air diverter door operation. After repairing the line(s) things were back to normal.
HTH
Robert
