coolant drain plugs in block
Old Jul 17, 2004 | 07:34 PM
PaulJ's Avatar
PaulJ
Default coolant drain plugs in block
I’ve been searching trying to find the coolant drain plugs in the block of my 99 LS1 without any luck. There are a series of equally spaced fully recessed bolts needing a 10 mm socket just above the oil pan, 4 on each side, the driver side one which is furthest back is just above the oil filter, then there’s one maybe 4 to 6 inches in front of this which is easy to get to, then another in front of this just behind the engine mount, then one in the front. I tried the easy one but it had a drop of oil on the end so it looks like this is for the oil galleys. There’s also a brass plug about the size of a quarter in the front which looks promising and another about an inch in diameter, this may be a freeze plug. I didn’t see anything else on the driver’s side, did I miss something?
paul
Old Jul 17, 2004 | 07:42 PM
LoneStarFRC's Avatar
LoneStarFRC
The bolts you're looking at (and loosening) sound like the cross-drilled main bearing caps. LS1's and 6's have 6 bolt main bearing caps on the center mains. I would look up the torque specs on these and re-torque. To my knowledge, we don't have coolant drain plugs anywhere. HTH
Robert
Old Jul 18, 2004 | 12:02 AM
Oldvetter's Avatar
Oldvetter
You don't need to pull freeze plugs to drain coolant, I drained nearly all thru radiator, just make sure it is level when draining.
Old Jul 18, 2004 | 02:18 AM
c5inphila's Avatar
c5inphila
There are 2 coolant plugs in the block, pass. side is above the starter,driver side is right in front of the engine mount, you can reach this one without removing anything. You need a 17 mm.allen hex socket.I only removed a 1/2 gallon more taking the plug out.
Old Jul 18, 2004 | 08:23 AM
mapman's Avatar
mapman
The procedure, in the Service Manual, for coolant change does not list pulling any drain plugs on the engine.
Old Jul 18, 2004 | 09:43 AM
Kenny94945's Avatar
Kenny94945
In the old days, after draining the radiator, we used to remove thermostats and then insert a special nozzel to force water and air through the block.
Could still work on a C5, but I do not know for sure.
Old Jul 19, 2004 | 03:45 AM
c5inphila's Avatar
c5inphila
Do it by the book then,But if you want to get it all out pull the plugs.
Old Jul 19, 2004 | 04:40 PM
Corvette00Car's Avatar
Corvette00Car
Default Freeze Plugs - Not
I just read an article and learned (wish to share and contribute). Although we commonly refer to them as freeze plugs they are not freeze plugs and are not there to protect the block from freezing. They are there because the holes are needed to clean out the sand and other material after the casting process. The metal plugs just close and seal the hole. Be good all.
Old Jul 19, 2004 | 10:26 PM
Ls1Rat's Avatar
Ls1Rat
To coolant drain plugs in block
