been here before but with the archived threads still being moved over....anyway when I turn the lights off i get that "running grinding sound AFTER the lights are down.....so is it a bad module?? I believe thats what I read before...I know its not the gear because I have BTDT and know that fix.
I had that same exact symptom and it was the gear. You can get brass upgrade gears fairly cheap from forum vendors. If you want to replace the entire module - Eckler's is a lot cheaper than dealers for that.
hmmmm..paid 39 for last one...different symptoms...oh well only take 30 mins to find out and 30 min to fix
You have lost some teeth from the nylon gear...
MidAmerica page 5-B sells a rebuild kit with a brass gear and all the stuff necessary to make it a one time fix... the cost is 50 dollars
