Fly Wheel question
Old Jul 19, 2004 | 10:26 PM
PHPD7102's Avatar
PHPD7102
St. Jude Donor '14-'15-'16
Default Fly Wheel question
I have heard from a few friends that switching to an aluminum fly wheel is a bad idea because you lose alot of torque. I guess my question is to those of you who have switched, any big diffrence?
I know the engine revs faster with aluminum but is the loss of torque that big or cause you any problems at all?
Old Jul 19, 2004 | 10:38 PM
tcmc5's Avatar
tcmc5
You won't lose torque, you'll gain it. Energy not needed to turn the flywheel is available to turn the rear wheels. You'll also lighten the car by about 12 lbs - easier to accelerate, easier too stop.
Old Jul 20, 2004 | 09:45 AM
Duck916's Avatar
Duck916
As said above, you don't lose torque, but some drivers may perceive a loss of torque because the lighter flywheel allows the engine to "bog" more easily upon clutch engagement when driven easy. This is because the heavier stock flywheel's inertia prevents the engine from slowing down much when you release the clutch. (That same inertia also slows down the engine's ability to increase rpms, which is why you're thinking about going to a lighter flywheel in the first place.)
Old Jul 20, 2004 | 12:23 PM
tcmc5's Avatar
tcmc5
IMHO there's no downside to this mod (other than cost) unless, perhaps, you're drag racing where the greater inertia of the stock flywheel may enable better launches with slicks. I don't drag race my car but I drive it very aggressively on the track and pretty aggressively on the street and there is no "bogging" at all. As for accelleration, the lighter flywheel is a definite plus and clearly superior to the stock unit which is twice the weight.
Old Jul 20, 2004 | 03:23 PM
Duck916's Avatar
Duck916
That's my point--driven aggressively, the lighter flywheel will give useful performance gains. The more timid amongst us might not like it so much. Your point about flywheel weight and drag racing is exactly right. Getting the correct weight to best launch the car is very tricky. Clearly, for road racing use, lighter is better.
To Fly Wheel question
