[Troubleshoot] IP cluster and console lights
Just noticed this problem tonight - new issue.
The IP cluster lights and console control lights don't turn on in the dark with the headlights raised.
The cluster lights and the console lights do work when the key is inserted and turned to the start position, but go out when the engine is started, and don't come on when the headlights are activated.
No codes set in the system.
When I had my C4, this would have been caused by the photocell above the DIC buttons.
Does anyone know if there's a fuse associated with this circuit? Something easy that I can check myself before I let a dealer look at it?
