Light wheels make you go fast!
Old Jul 23, 2004 | 01:43 PM
vai's Avatar
vai
Default Light wheels make you go fast!
Can anyone recommend the lightest wheels using stock tire size? I want lighter than the stock Z06 wheels.
Old Jul 23, 2004 | 03:07 PM
Nitro-C5's Avatar
Nitro-C5
Moderator
St. Jude 15 Year Donor
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '08-'25
Might want to look into CCW. They make very light and strong custom race wheels
Old Jul 23, 2004 | 03:12 PM
Gonzo's Avatar
Gonzo
Nitro, Great Avatar
Old Jul 23, 2004 | 03:57 PM
NPh2005's Avatar
NPh2005
The answer is phone books right?
Old Jul 23, 2004 | 04:04 PM
wamara's Avatar
wamara
Cruise-In II Veteran
You will be hard pressed to find many streetable wheels lighter than the OEMs. I think the CCWs are within a few ozs. of the OEMS. The SSRs sold by the TireRack are maybe about 1/2 lb. lighter per wheel. Good luck in your quest.
Old Jul 23, 2004 | 05:03 PM
leaftye's Avatar
leaftye
Kodiaks are the lightest conventional 3-piece, but it's not for the streets.
Old Jul 23, 2004 | 05:05 PM
blown in n.c.'s Avatar
blown in n.c.
O.Z. supraleggra III should be lighter in stock sizes. The 19x10 is only 24#!
Old Jul 23, 2004 | 07:55 PM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
Does anyone know what Corvette Magnesium wheels weigh, and ligther than stock?
Old Jul 23, 2004 | 08:28 PM
Umrswimr's Avatar
Umrswimr
From: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
They're about the same.
Best bet is to dump the runflats- they're really heavy.
Old Jul 23, 2004 | 10:08 PM
99C5Vert's Avatar
99C5Vert
St. Jude Donor '03-'11
I looked into this a while back and decided to go with Z06 wheels... I don't remember any of the numbers, but from what I remember, the aftermarket wheels that were lighter (many weren't), were not much lighter.
There is much more to be gained by dumping runflats if you haven't done so already... also, lighter tires are even more effective than lighter wheels, as they have a higher rotational inertia (further away from center of rotation).
Old Jul 23, 2004 | 10:21 PM
leaftye's Avatar
leaftye
Check here:
http://forums.corvetteforum.com/showthread.php?t=856772
Soo true, but this effect can also be coupled with having smaller diameter wheels with the (lighter) rubber to make up the rest of the weight, or even run a smaller overall tire/wheel diameter setup.
Eugene
Old Jul 23, 2004 | 10:44 PM
ALLKAR's Avatar
ALLKAR
Senior Member
Cruise-In V Veteran
How about an 18x10" Carbon Fiber wheel w/Titanium center.
14.2 lbs.??
Old Jul 24, 2004 | 04:38 AM
Ls1Rat's Avatar
Ls1Rat
14.2 lbs.??
THAT IS
Old Jul 24, 2004 | 07:26 AM
Rogue Wave's Avatar
Rogue Wave
CI 4-5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-16-'17
Now that is one mighty fine lookin wheel ya got there
Old Jul 24, 2004 | 12:53 PM
corvettebob1's Avatar
corvettebob1
The fronts are 17lbs and the rear are 19lbs and are supposed to be stronger and will not work harden like alum.
Old Jul 24, 2004 | 01:54 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
14.2 lbs.??
Ok, exactly how much do these wheels cost?
Old Jul 24, 2004 | 05:17 PM
leaftye's Avatar
leaftye
14.2 lbs.??
You're teasing right?!? This is too inticing for you to tell soo little, you have to tell us more! Who makes these? Do they fit on C5's? How much do they cost? Has anyone tried these on the street or track yet?
To Light wheels make you go fast!
Old Jul 24, 2004 | 05:22 PM
leaftye's Avatar
leaftye
Okay, I've calmed down a little and checked out Crossed Flags. Here's a link to the original thread about it. [Link]
And here's what a rep from the company had to say:
Originally Posted by Reed
Hi ! my name is Reed from Dyna Wheel some quick back ground on these wheels is as follows. We have been developing these wheels fo 2 years to OEM specifications specifically for the C5. We have mimicked the design of the C5 wheel as closely as possible (Rim profile/Hub). Size 18" x 10" weight 14 lbs. Rim finishes Black/black and gold/and red. Center colors Chrome/Black Chrome/Platnium Silver/Chromate. Cost $2990.00 per wheel. OEM sensors will fit and would not have to be taped on. These wheels have been tested to OEM specification and have exceeded them. This wheel was engineered with the racer in mind and we have used the appropriate materials to withstand heat that racing generates. The obvious advantage to these wheels is the reduction of unsprung weight we have reduced the weight 6 lbs per corner thats 24 lbs total unsprung weight reduction. Every pound of unsprung weight is equal to 8 lbs of sprung weight so by using these wheels you save 192 lbs of sprung weight and you feel every pound of it.
Old Jul 24, 2004 | 06:43 PM
FreddyG's Avatar
FreddyG
I saw those carbon fiber wheels at Bloomington Gold, and the salesman said that they were $3000 EACH! I did everything that I could not to choke when he said that! They were VERY COOL though, and I picked one up, and they were light! Nice, but out of my price range.
Old Jul 24, 2004 | 08:00 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Wow what a waste of money. Just add some power.
