90mm TB Poll
Old Jul 28, 2004 | 08:23 AM
SPEED DOG's Avatar
SPEED DOG
Originally Posted by Z06-JIM
The one, very annoying problem with my 90mm FAST Intake/Throttle Body combo is the Reduced Power Mode that comes in occasionally that usually only happens at slower speeds.
Finding a place to pull off the road and re-set the code can be a hassle at times.
It also surges at times trying to find an idle when coming to a stop. I can live with the slight idle hunting/surging but the reduced power mode is a real pain in the butt.
I have the Nicks T/B on mine.
Is anyone else having this Reduced Power issue?
You have to modify the calculated airflow table. Particularly at low throttle the bigger manifold/tb setup brings in so much air the computer sees a fault and goes into reduced power mode. Do a search here; we had an ongoing thread about this and its solutions a couple of months ago.
You'll need LS1 edit or HP tuners to do this (or someone with this software who knows how to tune for this).
The hunting/surging also reflects a need to adjust your idle tuning, a very common problem with these as well. Take a look on LS1tech.com as well; there was a detailed thread on idle tuning about two/three months ago as well as some good recommendations from "NoGo" who'se a pretty knowledgeable tuner.
Our own RJ helped me immeasurably with this (as he continues to do). You can get this right, even on pretty radical setups, but it does take some time.
Good luck.
Old Jul 28, 2004 | 11:20 AM
NEPTUNEBILL's Avatar
NEPTUNEBILL
Hello Doc--hows it coming--Nick is visiting friends this weekend near me and we are going to install his lastest version and tweak it with edit--this latest version has bearings for the T plate and he has been working towards and been quite successful switching the new TB with the stock tuning for the stock unit with very little tweaking in the idle areas particullarly--we will see how it goes with the 436--after we have it idle and run I'll take it back down for some dyno pulls and final tweaking in all area's--this will be a good test for strokers and if nothing else we will find out what needs to be done to make the TB conversion a much smoother operation--I will post results
Old Jul 28, 2004 | 06:44 PM
whale's Avatar
whale
GOGO, what happened when you bolted on the Williams unit? Was your car tuned with a FAST unit first? Did the new unit do OK with out any tuning? Thanks....Wayne
Old Jul 28, 2004 | 07:16 PM
The DBK's Avatar
The DBK
I'm aware of this TB, but for the time being(with crossed fingers knocking on wooden rabbits feet) it appears that the TPIS in fact CAN be tuned. I spent a day and a half with Pete K at Agostino tuning my F.A.S.T setup with the TPIS throttle body, and although it was absolutely bonkers when I first got it, I've since put on a shade under a thousand miles and it's working well. Or I should say as well as you could hope.
The only issues I'm having are the hunting for idle at stoplights, which virtually always goes-car slows down, goes to about 1500rpms while car is rolling to stop, dips to about 850-back to about a grand. Which is livaeble. Occasionally the car will stall after high rpm usage while it searches for idle, but that's what the track is for.
They got rid of my amazingly irritating automatic cruise control(the car would accellerate to given RPMs in the first 4 gears) and the self-powershifting the car was doing(upon pressing in the clutch, revs rocketing to 3k).
Oh, and how does 11.58 @ 124+ on a 1.88 60ft sound for the first trip at the track at an almost 2k DA(ok, so it was only 1600)? ET Streets here I come!
Old Jul 28, 2004 | 07:57 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
DBK - your car would have much better manners with Nick's TB.......it would be polite.
gojo's car is an A4. Compare the tuning tables (complexity) of an automatic to a 6spd . There is a huge difference in the finesse and precision neccessary to tune an A4.
My point is gojo's car idles, AND transitions to idle, like it is stock and it IS an A4. It has a large cam, ported heads etc. and the A4 functions essentially as a stock setup.
What most of us are looking for is an increase in HP without sacrificing "Street Manners". This TB provides that.
A day and a half of tuning for compromised expectations is now history.
No frustration.
joel
Old Jul 29, 2004 | 04:57 PM
gojo's Avatar
gojo
Joel,
Thanks. I would have liked to take credit for tuning, but the cat's out of the bag. Nick's TB is easy to tune.
Whale, I would be surprised if it didn't need tuning after being tuned for a Fast or TPIS TB. The experience has been if the car comes in tuned to run well, with a stock TB, it will need little or no tuning with Nick's subsequently installed.
Old Jul 31, 2004 | 11:36 AM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Joe - You're welcome.
As I've said before - it's nice to see comments of Modesty.
(On another note- Gameover posted the g/cyl calcs the PCM uses with the VE table. I checked my scanned MAF-g/cyl values against the PCM calculated g/cyl values using NoGo's and Gameover's VE values. NoGo's is more accurate for my car - it's back to his derived table . Gameover's is off/lean by around 20%. I guess this analog man is a little bit of a Geek - My brother JAY KOCH (Forum name) should be proud.
NoGo is THE MAN!!
Old Aug 1, 2004 | 08:09 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
NoGo is THE MAN!!
The poll seems to have gone very well. Many of us know about the 90mm Nick Williams TB option.
Old Aug 1, 2004 | 08:59 PM
SPEED DOG's Avatar
SPEED DOG
Hiya Bill; good to hear from you.
Let me know how it goes with the latest TB: I suspect I have an early one, based on its time of install at LG. I DID have idle tuning issues, and still have some start/restart stuff going on, so wonder if I should go to an updated TB as well.
Old Aug 1, 2004 | 09:21 PM
X_03_Cobra_guy's Avatar
X_03_Cobra_guy
why not make a dual bore throttle body. One side is the stock 70-78MM size and works/mimics the fly-by-wire throttle body. And, a secondary is maybe 50 or 60MM and is a switch open at 3/4 to full throttle only.. Kind of like the old secondaries on a carb. That way you have WOT airflow with low rpm driveability. Just a thought.
