battery box drainage
Old Jul 25, 2004 | 01:04 AM
Leonarer's Avatar
Leonarer
Default battery box drainage
99 was on a rack the other day and noticed the frame has rust down the rail from the battery box. I assume this is normal. What is a good fix or what battery will not leak. The biggest problem I see is there is a computer with it's wiring harness awfull close to the corossion.
Any suggestions.
Old Jul 25, 2004 | 05:09 AM
CAPN17's Avatar
CAPN17
It is not normal, it is a sign of acid leaking from the battery. You need to check for acid damage and get any left over acid out. Put in a nonleaking battery and remove the corrosion and get a good coat of paint over the area after neutralizing the acid left. It is a BAD thing.
Old Jul 25, 2004 | 10:26 AM
Oldvetter's Avatar
Oldvetter
Get an AGM battery, they do not leak. Sometimes the leaks follow the battery cables, check for that. Consider yourself lucky if the computer or connections aren't affected.
Old Jul 25, 2004 | 11:04 AM
Bill C's Avatar
Bill C
Get an Optima..
To battery box drainage
