Noisy lifters ...
Old Jul 25, 2004 | 10:38 PM
SPDaylightFan's Avatar
SPDaylightFan
Default Noisy lifters ...
I have a stock LS-1 automatic. It is a 2000 coupe with 22,000 miles on it. In all ways the car is immaculate. BUT, when started cold and until the oil temp comes up the lifters make more noise than I think should come out of this engine. Anyone have an experience such as this.... should I take it in on the extended warranty?
Old Jul 25, 2004 | 11:38 PM
cerino2000's Avatar
cerino2000
Seems to me that that is a well known 'normal' problem with Ls1's. I don't think I would be too worried about it unless it was REALLY loud but if it bugs you, take it in while it is under warranty.
Old Jul 25, 2004 | 11:45 PM
CAPN17's Avatar
CAPN17
I would make sure it is the lifters and not piston slap.
Old Jul 26, 2004 | 06:31 AM
SPDaylightFan
thanks guys, I am sure it is lifter noise ..... you can actually locate the noise when you go under the hood. The right bank seems loudest.
Yeah, it bugs the heck out of me .... In the "good old days" you grabbed a wrench and feeler guage and pulled the valve cover. Not any more ... sigh!
thanks again ....
Old Jul 26, 2004 | 11:53 AM
crainholio's Avatar
crainholio
The noise you're describing is pretty common, but may go away or minimize depending on your oil selection. With 0W-30 Syntec, mine had it under same conditions you listed. When I went to 5W-40 Mobil/Delvac-1, it was pretty much gone. Now running Mobil-1 15W-50 for racing season, and it's quiet.
The LS1 has an aluminum block and a much more aggressive cam than the old Chevy technology which was notably quieter. The LS1 doesn't dampen noise as well as the old iron blocks, and it has an inherently-noisier valvetrain.
GM wasn't running 0.500"+ lift cams and 1.7:1 rockers in the old quiet days. You want quiet, go get a wimpy cam and weak valvesprings...or start experimenting with your oil.
Old Aug 1, 2004 | 12:16 PM
Cool Terry's Avatar
Cool Terry
Cruising
Default May be piston slap
thanks again ....
I too thought my noise was lifters and the majority of the sound was coming from the right bank as you have described yours. However it ended up being piston slap and I recently had warranty repairs done.Do a SEARCH on this site and type in Piston Slap and you will see all the conversations on this topic.
Terry
Old Aug 1, 2004 | 12:23 PM
Patches's Avatar
Patches
Check out page 5 of Hib's article which addresses this issue along with excessive oil consumption.
Hib Halverson's Article
Old Aug 1, 2004 | 06:23 PM
VetteSiNz's Avatar
VetteSiNz
And if it's the piston slap; the dealer should replace it for free. One of my co-worker has the same problem - piston slap and the dealer is currently repairing it.
To Noisy lifters ...
