My 02 with 26,000 miles on it appears to be leaking a green fluid.
I am not sure if this is a Differntial or Transmisson Leak .
(or if it is something else)
Not sure if it matters, but it is a 6-speed.
Thanks everyone...the differential should be fixed soon.
sounds like diff. leak. trans fluid is red. look at the drivers side where the drive axle comes out, this is the most likely spot to leak. chev. allows 1.6 hours to fix this. there is a tsb on it
