LS1 versus LS6 Block
Old Jul 26, 2004 | 10:22 PM
pmcw's Avatar
pmcw
Default LS1 versus LS6 Block
In a 2001, how can I tell is my coupe has an LS6 block?
Thanks, pmcw
Old Jul 27, 2004 | 02:47 AM
bluecoupe's Avatar
bluecoupe
Cruising
If it is a 2001 coupe (Targa Top) it is an LS1 if it has a 2001 fixed roof hartop it is the first year Z06.
Old Jul 27, 2004 | 09:23 AM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Some of the LS1s were built with a LS6 block. I am not sure how you tell.
Old Jul 27, 2004 | 09:24 AM
pmcw's Avatar
pmcw
Yes, I know that, but it's my understanding they started using the new LS6 block in 2001. However, there was a change-over date so I don't believe all 2001 non-Z06's had the LS6 block (not the LS6 cam, heads, etc.).
Old Jul 27, 2004 | 10:05 AM
Duck916's Avatar
Duck916
There's a machined area on the block deck just in front of the passenger side head. On an LS6 block the machined out portion is larger than on an LS1. Sorry, I don't have any pictures, but if you look at a 2002 and later car, and compare it to a 2000 and earlier car, you'll see the difference.
Old Jul 27, 2004 | 10:48 AM
ragtopws6's Avatar
ragtopws6
Casting # 12561168 is located behind and below driver's side cylinder head. Use a small mirror to see it.
Old Jul 27, 2004 | 02:19 PM
Rattler71's Avatar
Rattler71
Sooooo does that number mean it is a LS1 or LS6. Sorry if I am missing something here.
Scott
Old Jul 27, 2004 | 05:22 PM
ragtopws6's Avatar
ragtopws6
If you have that casting # that means you have a LS6 block.
Old Jul 27, 2004 | 05:53 PM
mwittkopf's Avatar
mwittkopf
As stated, if it is a 2001, it should have a new (LS6) block. My 2001 TransAm built in the first week of October had a new block. I imagine that the Corvettes were switched over by then as well. I personally haven't seen a 2001 yet with an old block and I've seen quite a few!
Mike
Old Jul 27, 2004 | 07:11 PM
Mike Mercury's Avatar
Mike Mercury
THANK YOU !!!
will be checking my July 2001 built '02.
Old Jul 27, 2004 | 11:13 PM
ragtopws6's Avatar
ragtopws6
Originally Posted by Mike Mercury
THANK YOU !!!
No thank you, Mike. I performed your Frost King insulation couple months ago and I can't be happier!
-Rick
Old Jul 28, 2004 | 12:49 PM
ersatz928's Avatar
ersatz928
My 01 coupe was built in Oct 00. It does not have the LS6 block.
Old Jul 28, 2004 | 03:19 PM
Duck916's Avatar
Duck916
THANK YOU !!!
Go ahead and check it, but I am almost positive all 2002 model year cars have the LS6 block casting. The switch went in late in 2001 model year production. My 6/01 build date '01 MY car had the LS6 block casting.
To LS1 versus LS6 Block
