Which rings to use?
Jul 27, 2004 | 12:26 PM
Which rings to use?
I'm going to have my 2001 LS6 re ringed (Not by a Dealer)
What rings should I use?
Thanks in Advance
Jul 27, 2004 | 05:39 PM
I had my 2001 re-ring done at the dealer. They used stock 2002 Z06 style rings but with a sharp leading edge to break in quickly. These work well for people 99% of the time.
Jul 28, 2004 | 08:46 AM
Jul 28, 2004 | 08:45 PM
Hello Z060ntrack.
I had my 2001 Z06 re-ringed also. We used the rings recomended by GM to eliminate the oil consumption problems (they worked great).
Part number of the ring kits I purchased was 88894299. You need eight sets. I got mine from Fitchner Chevy (forum vendor).
While you are in there it would be a good time to upgrade the rod bolts and timing chain.
Good luck.
Perry
Jul 29, 2004 | 07:41 AM
Thanks, I've already done the timing chain but the rod bolts are a good idea.
I'll cross reference the part number to see if it matches the replacement program from G.M. or is different from the 2004 rings.
Jul 30, 2004 | 12:53 PM
Interesting, the part number you used was not the part number that G.M. lists for the TSB on the 2001 - 2002 LS1/LS6 which is 88984247 which is also the part # for the 2004 LS6.
Jul 30, 2004 | 10:20 PM
Quote:
Originally Posted by Rollin Black
Hello Z060ntrack.
Good luck.
Perry
Go with the APR rod bolts. For the few extra dollars its worth it if you like to spin the engine up to redline often.
Aug 2, 2004 | 08:58 AM
What is a good source for the APR rod bolts?
Aug 2, 2004 | 09:31 AM
CI 3-4-5-9 Veteran
Quote:
I would get the ARP studs as you can reuse them more times. Try any of the forum vendors. Thunder, Speed Inc. etc
Aug 2, 2004 | 06:55 PM
According to OIL CONSUMPTION-SERVICE BULLETIN I have, "Higher Than Expected Oil Consumption (Replace Rings) #01-06-01-023"
It states under parts: Piston Ring Kit #88894299, Qty. 8
These are special rings to fix the oil consumption issue and seat quickly from what I recall. They are not just replacement Z06 rings for a new motor.
I hope this helps. If you want, I can email you my copy of the service bulletin.
Thanks, Perry
Aug 2, 2004 | 06:58 PM
Quote:
93Polo, ARP has studs to replace the GM rod bolts or are you talking about head studs?
I think z060ntrack is talking about rod bolts which yes, I would suggest ARP.
Thanks, Perry
