Help with these 2 codes?
Old Jul 27, 2004 | 06:20 PM
C5JONNY's Avatar
C5JONNY
Default Help with these 2 codes?
What do these codes mean?
po 0420-TWC system low efficiency bank 1
po 0430-TWC system low efficiency bank 2
Old Jul 27, 2004 | 06:34 PM
dpd's Avatar
dpd
they mean the cats aren't working.the cat efficency is measured by the rear 02 sensors.if the voltage of the rear o2's compared to the fronts are close to the same,that tells the pcm the cats aren't working nd flags the fault.
