Nitto 555 R's ??
Old Jul 28, 2004 | 12:18 AM
mdhmi's Avatar
mdhmi
Default Nitto 555 R's ??
Current setup: ( Stock Y2K polished rims )
Fronts: 17's P245/45ZR17
Rears: 18's P275/40ZR18
I *need* new tires on for the rear. The stock run-flats just aren't working with my 500+ rwhp ProCharger setup.
Can I *safely* run Nitto 555's on the back and keep my stock run-flats up front? Which size Nittos should I get for the back????
Ideally I would like a tire that I can run on the street and the track. If the tire only last 10-15K miles that is fine with me ( my car is a Y2K and has 15K miles on it ).
Anything else I should keep in mind??
Please advise.
Thanks,
Mark
Old Jul 28, 2004 | 08:28 AM
mdhmi's Avatar
mdhmi
Anyone ? TTT
Mark
Old Jul 28, 2004 | 08:31 AM
robz's Avatar
robz
I'm running nitto 555r2 in back on a stock zo6 rim and f1's up front with no problem. Best size for zo6 rim is 305 35 18
Old Jul 28, 2004 | 06:21 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
Old Jul 28, 2004 | 06:43 PM
Jeff Jeff's Avatar
Jeff Jeff
I had the Nitto's (before I did H/C) and they were OK at first, but as they started to wear, they lost a lot of traction. Also their wet traction was pretty bad. I now have the pilot sports and they are a much better tire in my opinion, even with H/C.
I have some trouble with traction at 417 rwhp in 1st and 2nd with stock tire sizes, I would think you will need wider rims to get enough traction with 500rwhp.
Old Jul 28, 2004 | 07:01 PM
mallett435's Avatar
mallett435
I basically have the same power 413rwhp/420rwtq and I have the 335/30/18 Pilot Sports....they still SUCK straight line. Like being on a skateboard...all over the place. Corners are awesome though. I put Nitto DRs 315/35/17 on some spare wheels and straight line is shocking. Even cold and from a 10mph roll, I can't spin them.
Old Jul 28, 2004 | 07:15 PM
NXTFAZE's Avatar
NXTFAZE
Please advise.
Thanks,
Mark
Hey Mark,
I have the Nitto 555's on all corners.....
I think they are a really great street tire....not the best in the rain compared to BFG KDW's.....
I would not set up w/ 2 different style tires front/back since they have different handling tendencies.....
If you are at 500 hp.....and looking at getting new tires, definately go wider!!!!!!! I'm not sure how wide you can get w/ your stock rims....295's should fit easily but i would push for 305 or 315's to put more hp to the ground......
Keep me posted, looking at newer (wider rims) in the near future....
-Marko
Old Jul 28, 2004 | 07:57 PM
JUSTIFIED C5's Avatar
JUSTIFIED C5
I just put nt555r's on 10.5" zo6 wheels, 305/35/18'. I have 440rwhp, with 4.10's. These are excellent for traction.
Old Jul 28, 2004 | 08:15 PM
add's Avatar
add
Default Nitto's
I have nittos on all four corners as well, they have been a great tire compared to the run craps. I dont have RWHP you have...yet... I have over 10000 miles on themand still look great. Traction in the rain is a little iffy but on dry pavement they are hard to beat for the price. Thats my $0.02.
TD
Old Jul 28, 2004 | 10:24 PM
Motorsportsline's Avatar
Motorsportsline
St. Jude Donor '06
I put Nitto 555's up front and 315-35-18 555 DR's out back and love 'em. Living in South Florida I get to see plenty of rain and have no problems. I'm supercharged A4 with 3:42's and Yank SS3200. I can spin them at will but have respect for wet conditions. Just my $.02
Old Jul 28, 2004 | 10:41 PM
NIGHTMARE...2001's Avatar
NIGHTMARE...2001
I just purchased 305/35-18 Nitto 555r DR's for the rear, and 275/40-17 Nitto 555r Extremes, for the front, to replace my run-craps. Can't wait to put them on this weekend!
If you decide to go with this setup, get some 17x9.5's and 18x10.5's, so they'll fit properly. Good luck!
Old Jul 29, 2004 | 12:24 AM
CRWDDYZ's Avatar
CRWDDYZ
Did you have the tires heat cycled before installing them ?
Old Jul 29, 2004 | 01:32 PM
mdhmi's Avatar
mdhmi
I'm not opposed to replacing all four tires. I would like to keep my stock rims if possible. What I don't want to do is have a separate set of tires that only get used at the tract ( changing tires every time I want to head out to the track sounds like a PIA ) . My car is not a daily driver, however, I do drive my car a few days a week to work. No road trips or winter driving in my Vette ( that's what the truck is for ).
Does anyone know the exact sizes I should order to replace my stock run-flats? I have the polished rims on my 2000 Vette. Currently I have P245/45ZR17's in the front and P275/40ZR18's in the rear.
My goal is to have one set of tires that I can use on the street and that hook well at the track. I really don't care if the tires only last 10,000 - 15,000 miles ( that's a couple of years of driving for me ) .
Thanks again everyone for helping,
Mark
Old Jul 29, 2004 | 02:50 PM
add's Avatar
add
Default Nittos
They are a good choice for replacement of the run craps, I have had no complaints. The stock size is the same as you need. Get them you will enjoy them.
To Nitto 555 R's ??
