Injectors
Old Jul 29, 2004 | 07:37 PM
Watch22's Avatar
Watch22
Default Injectors
How many of you have change their injectors? I was in the process of getting my car dyno tuned and the injectors are close to the MAX. With the mods in my sig I'm currently hitting 375HP on the dyno, there is still a bit left in her hopefully 385. I can't finish tuning the car because the injectors are running at a 85%-95% duty cycle from 3900 - 6500RPMs, and causing the car to run very lean on the top end and ping like crazy. If I try to add fuel it takes the injectors to almost 100%.
I just ordered SVO 30# injectors and should be here on Friday. I don't see to many people talking about replacing injectors. I would not have noticed unless I scanned while on the dyno.
Old Jul 29, 2004 | 09:17 PM
Greg_E's Avatar
Greg_E
Something doesn't sound right. Those injectors should be good to around 450RWHP, from what I've read. at 375 RWHP , you should have no reason to replace the one's you have. I have no problems running the 28.8 # injectors with 400 RWHP and others with more HP are using them, also with no problems.
Old Jul 30, 2004 | 12:23 AM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Are you on a Dynojet???? Mustang - Load dyno???
Old Jul 30, 2004 | 12:39 AM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Default Injectors
I ran my 28 Lb. Injectors with 495.3 RWHP with no problem........
Old Jul 30, 2004 | 01:22 AM
mdhmi's Avatar
mdhmi
I put in 42's with a Racetronix fuel pump. No problems here.
Good luck,
Mark
Old Jul 30, 2004 | 08:50 AM
dmtnt's Avatar
dmtnt
St. Jude Donor '03-'05-'06 & '12
I just put in SVO's. My only mods before were a Vararam, some LS1Edit'ing and a Shaner S2. At WOT, my injector duty cycles were 100%, and even 101% on one log. Now with the SVO's, they're in the 80-85% range at WOT. IMO, the stock injectors are inadequate for an LS6, even with just bolt-ons.
Old Jul 30, 2004 | 09:24 AM
mallett435's Avatar
mallett435
I agree 100%. I had 383rwhp and IDC was 100% with stock injectors. After upgrading the FAST intake and LG headers, my tuner said I better upgrade injectors or be sorry and it gives the tuner more room to work with fuel trims. Now, I have the SVO 30s with 413rwhp/420rwtq and my IDC is still in the 90s.
People say they ran 4xx rwhp with stock injectors, but that doesn't mean it ran optimally. Unless a scan is done, they don't know what they are losing or hurting by using stock injectors. No way is their IDC under 100% with stock injectors and ideally you want it in the 80s. Bottom line to me is that they are not expensive and why not be safe than sorry. You will be able to tuner more efficiently having the bigger injectors. You can tune bigger injectors if you have a little too much injector to work, you can't tune smaller injectors (than you need) to compensate for size.
Chris
Old Jul 30, 2004 | 09:46 AM
Watch22's Avatar
Watch22
The car was run on a dynojet with wideband. The SVO 30# will be here in a few hours from UPS.
I was at the dealer this morning getting the latest updates in the computer and the vette tech's who also have high HP vettes said the stocks are only reliable to about 370RWHP. Anything over the 80% duty cycle the injectors have a chance of no spraying correctly.
To Injectors
