I will finish installing my LG headers, Z06 intake manifold, plugs and wires tonight. I am wondering what I should expect in terms of codes and idle? The headers I bought have no cats and I did not buy oxygen sensor sims. I plan on having them edited out in a tune. I did a couple searches and couldn't find anything. Thanks for your help.
P0133, P0154, P1133, P1134, P1153, P1154, possibly P0491.... Maybe a few more. Really varies/depends.
Use the D.I.C. to retreive the codes, and then get them edited out.
The Idle could change with the codes that come up but once reset it should Idle normal. You will for sure need a dyno to get everything working together.
Thanks for the info. Everything seems fine, I hope. I finished and let the car idle for a while to let the grease burn off. Then I drove it around for about 5 minutes and the check engine light came on. I went back home and checked the codes. There were lots of history codes that seemed related to the battery being disconnected. So I reset them all and drove around again. I went about 15 minutes and 10 miles with a few hard WOT launches(no check engine light this time). Then I checked the codes again and got only P0140 and P0160 which says the oxygen sensors are missing. Sounds good right? You'll here from me again if I have trouble Thanks again guys.
