dealer alignment
Old Jul 30, 2004 | 08:44 PM
C5inWV's Avatar
C5inWV
Default dealer alignment
I called my local chevy dealer to schedule an alignment for my '97.
The service manager told me that he couldn't do a 4 wheel alignment on my car... he said no one could because it is impossible to do a 4 wheel alignment on a rear-drive car. I thought maybe I was using the wrong terminology, so I said I just wanted to set the camber and castor on the rears as well as the front. The fellow said "no can do."
I know I paid for a 4 wheel alignment a few years ago, and I have an Ecklers catalogue that shows the proper castor/camber settings front and rear for different track applications.
Does this guy know what he is talking about? Would you take your car to this shop?
Old Jul 30, 2004 | 08:58 PM
Yibbutkeen's Avatar
Yibbutkeen
The dealer is full of :
I wouldn't even think of letting him work on my car unless it was an absolute last resort.
I'd try and find a good tire place that specialized in high performance tires etc. If they don't do the alignment they might have a good idea who does.
Good luck
Old Jul 30, 2004 | 09:00 PM
IM QUIKR's Avatar
IM QUIKR
RED FLAG on the playing field. Run like hell.
I just had my local Firestone service center in Naperville align all 4 wheels and stood there while he did it. They are a great bunch of guys there. Your service guy obviously has no clue. Besides that, it will come home with another problem as dealers are well known for doing. Oh, I almost forgot $64 plus tax.
Earlier that day I walked out of NTB tire center because they quoted $70 and then came back and said it was a "special" and the price would be $100, what ever the hell that means. To me, it means Corvette tax. So I told them to forget it and drove away. :mad
Old Jul 30, 2004 | 09:18 PM
T_Vert's Avatar
T_Vert
where in naperville? IM in need of an alignment myself
dav
Old Jul 30, 2004 | 09:41 PM
Threed's Avatar
Threed
From: GOCC - Rebels Without A Clue Santa Barbara, CA
That boy better not give up his day job.
Old Jul 30, 2004 | 09:58 PM
IM QUIKR's Avatar
IM QUIKR
dav
Firestone on Washington St just south of Gartner. I think it was Dave that did the job and he was careful to have 2 guys lift the fenders to clear the rack up and down. He took his time and got it right.
Old Jul 30, 2004 | 11:31 PM
leaftye's Avatar
leaftye
Talk to some of the guys in your local Solo II group. Real racers will know the best shops. The guys in my group told me about a place that regularly aligns Formula Ford race cars, and superlow street cars.
Old Jul 31, 2004 | 08:46 AM
007Duc's Avatar
007Duc
The dumb a$$ probably thinks Vettes still have solid axel rear ends like in the 50's
Old Jul 31, 2004 | 01:28 PM
C5inWV's Avatar
C5inWV
I thought he was full of it.
Old Jul 31, 2004 | 04:08 PM
6 speed Sid's Avatar
6 speed Sid
This guy is the service manager?? He must still be thinking in terms of the 60s'. Sid.
Old Jul 31, 2004 | 07:30 PM
birch64's Avatar
birch64
dav
dave's theres a place in arlington hts dave and jims auto body that does great alignments....................call me and i'll give u more info...
Old Jul 31, 2004 | 07:43 PM
GaryZ06's Avatar
GaryZ06
That guy is an idiot......I would go back with proof that is can be done
Old Aug 1, 2004 | 12:07 AM
T_Vert's Avatar
T_Vert
mike i know where dave and jims is i had a car repainted there after an accident
thanks
dave
Old Aug 1, 2004 | 12:44 PM
VetteTech81's Avatar
VetteTech81
In all fareness maybe this service manager is not familiar with the car.. most service managers never worked on cars.. the techs might be skilled.. but either way I agree if the manager has no clue about simple things like the alignment of a vette.. then I would run.. RUN RUN FAR and HARD find a nice independent shop that can accomodate your needs..
-Rick
Old Aug 1, 2004 | 05:39 PM
alanh's Avatar
alanh
In defense of the dealer, most likely, what he should have said is that a four wheel alignment couldn't be done with their type of equipment, but the idiot should have known that with the proper equipment, it can be done. The dealer where I purchased my C5 had laser alignment equipment, but didn't have the equipment to do a proper 4 wheel alignment on a rear drive car with a limited slip diffferential. The problem comes with "zeroing" each head unit after it is mounted on the wheel. Each wheel must be turned individually to zero that laser head and with limited slip, you can't turn just one rear wheel by hand and if you jack up the whole rear end, both wheels turn and that screws up the settings in the alignment equipment. At least they knew why they couldn't properly do the alignment.
Old Aug 1, 2004 | 05:58 PM
Ls1Rat's Avatar
Ls1Rat
how do you measure rear caster ?
rear camber and toe make sense but rear caster ?
Old Aug 1, 2004 | 06:06 PM
alanh's Avatar
alanh
There is no rear castor. Actually there is no front castor until you turn the wheels right or left, then you get castor. The castor increases as the wheels are turned, but I think the setting is done when the wheel is setting at a 20 degree angle. Since the rear wheels don't turn right or left, there is no rear castor setting.
To dealer alignment
Old Aug 1, 2004 | 08:32 PM
C5inWV's Avatar
C5inWV
You're right... the Ecklers ad only states caster values for the front.
Old Aug 2, 2004 | 08:40 PM
leaftye's Avatar
leaftye
The instructions in my alignment tool says the wheel has to be turned while the camber device is attached to the wheel. Caster is a measurement of a kind of camber change that occurs while the wheels is turned. Please note that it's different from roll or bump steer. I can't really explain how lots of caster (good) can exist with 0 toe, 0 roll steer, and 0 bump steer....but maybe that's not possible seeing as how that would be very nearly the perfect suspension.
Eugene
Old Aug 2, 2004 | 09:55 PM
Vettlldo's Avatar
Vettlldo
He is full of
