help with manual trans. removal
Old Aug 1, 2004 | 02:33 PM
happyhourvette's Avatar
happyhourvette
Default help with manual trans. removal
i have a 2000 6-speed trans. the trans grinds when going into reverse i can hold it in reverse the car will back up. if i don't hold it in it will jump out of gear.does anyone know what the problem is? tried to adjust shifter didn't help. if i have to pull the trans where can i get a copy of a manual?
Old Aug 1, 2004 | 03:45 PM
Apollo's Chariot's Avatar
Apollo's Chariot
I bought my repair manual from the Helm Books web site. Authentic GM factory service manual was $135 for my '99 vert.
Mike Mercury's Avatar
Mike Mercury
here is my web page with A4 removal; should be very close to the mn6
http://mikemercury.home.att.net/342.htm
Old Aug 1, 2004 | 05:40 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
You can replace reverse gear,fork,and reverse syncro without removing the trans Pull the rear end and simply remove the reverse gear housing to access
Old Aug 1, 2004 | 09:26 PM
Mike Mercury
WOW; I didn't know that
Old Aug 1, 2004 | 10:02 PM
happyhourvette
this is happyour again i have the problem with my reverse gear in my 2000 6-speed all other gears are fine. do you think it's the shifter fork or the syncro or both i was getting ready to remove both trans and rear end i need help in knowing what to remove and what to loon for i have directions for removing a auto trans but not a manual. thanks . and i wanted to thank for all the help you gave me on the vacuum hoses under the battery saved me from replacing the air pump
Old Aug 2, 2004 | 11:42 AM
Mike Mercury
glad to know it fixed the problem.
To help with manual trans. removal
