Non-Newbie Simple Lowering Question
Old Aug 2, 2004 | 04:03 PM
BQuicksilver's Avatar
BQuicksilver
Cruise-In III Veteran
Cruise-In IV Veteran
Default Non-Newbie Simple Lowering Question
Guys, I feel like a fool for asking, but:
On the rear wheels, when lying underneath the bolt looking up at it, holding the 21mm nut on top still with a wrench. Which direction do you turn the bottom (18mm) bolt to LOWER the car?
Clockwise or Counterclockwise?
Old Aug 2, 2004 | 04:19 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Counterclockwise
You want to put more distance between the bolt head and nut
Old Aug 2, 2004 | 04:21 PM
rutiger's Avatar
rutiger
my vote is for ccw (i think). it seems that you need to back the nut off to lower it. so whatever direction backs the nut off is it (i think).
Old Aug 2, 2004 | 05:57 PM
BQuicksilver
Everyone agrees it's CCW?
I think the reverse-threaded bolts up front have me a little turned around.
Old Aug 2, 2004 | 06:13 PM
jrose7004's Avatar
jrose7004
Counterclockwise!
Old Aug 2, 2004 | 06:14 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
You turn both front and rear counterclockwise.
BTW, the front bolts are NOT reverse (LH) threaded. You want to loosen the bolts as if you were threading them up out of the top of the spring. Of course you can't thread it up out of the spring because of the bushing...but you're still turning in the same direction. I don't know why this confuses so many people, but it is a standard RH thread.
A simple way to remember thiswhen adjusting either end of the car is "loosen to lower".
To Non-Newbie Simple Lowering Question
