Frame question
Old Aug 2, 2004 | 10:50 PM
99C5Vert's Avatar
99C5Vert
St. Jude Donor '03-'11
Default Frame question
Posted this in C5General, but perhaps it's more appropriate here:
I've noticed these spots on my frame, on both front sides near the suspension. In the pic you can see the black area that I wiped clean, and the bright silver colored spot in the middle of the clean area. Looks like the top black layer is peeling.
There is absolutely no sign of any rust, or damage to the frame.
Does anyone else have this? I haven't seen it near the rear suspension.
Old Aug 3, 2004 | 05:07 PM
99C5Vert's Avatar
99C5Vert
ttt
Old Aug 3, 2004 | 05:40 PM
MrEracer's Avatar
MrEracer
The inner fender wells are glued to the frame with a thick epoxy. Looks like a glob of this has dropped away leaving the bear spots. This is not a problem. You might spray some black paint on the bare spots to prevent rust.
Shirl
SDRE
Old Aug 10, 2004 | 01:17 PM
99C5Vert's Avatar
99C5Vert
MrEracer, thanks for the response. When I touch it, it definitely feels like the black layer is gone - there is an indentation there, not a raised area.
Old Aug 11, 2004 | 01:10 PM
ersatz928's Avatar
ersatz928
The frame rails are galvanized steel (the silver color) with a black painted finish. The galvanized coating (zinc) will prevent it from rusting.
To Frame question
