CLB Service column lock
Old Aug 5, 2004 | 02:30 PM
Mr Daddy's Avatar
Mr Daddy
3rd Gear
Default CLB Service column lock
Hi again I have been reading all about this CLB on the forum and there is a recall here in the UK, My car is booked in on Saturday morning at the dealer in Manchester (UK) for other jobs.
But pull key wait 10 sec message has poped up along with service column lock I have not moved the steering wheel incase it locks What do I do?
Old Aug 5, 2004 | 04:19 PM
JC in XTC5's Avatar
JC in XTC5
Is the column currently locked or unlocked. If it's unlocked, then you can drive the car - the BCM will not cut the fuel since it is in the "safe" fault mode with it unlocked. You should be OK to use it.
However if the steering is currently locked, then you're SOL since the problem is it won't unlock. You may be able to force it to unlock - there's several posts on things to try like banging on the steering column and pulling the wheel hard to the right while turning the key.
Good Luck.
