corsa x pipe
Old Aug 5, 2004 | 10:17 PM
[ Ls1 ]'s Avatar
[ Ls1 ]
Default corsa x pipe
well im about to purchase the corsa x pipe...please correct me if im wrong, but the x pipe bolts on after the cat, correct...meaning i would not have to get o2 simulators...and has anyone burned any o2 sensors after headers x pipe and exhaust....
Old Aug 5, 2004 | 10:28 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
you are correct in that the x pipe goes on after the cats... specific cutting instructions come with the X pipe.
Old Aug 5, 2004 | 10:35 PM
LoneStarFRC's Avatar
LoneStarFRC
True story. Oh and BTW, be absolutely, positively sure that you measure correctly before cutting. Personally I would recommend you remove your mid-section pipes beforehand and lay the Corsa X pipe on top.
Robert
Old Aug 6, 2004 | 12:17 AM
[ Ls1 ]'s Avatar
[ Ls1 ]
Default thanks......
thanks a lot for ur input........i will use caution when cutting my mid-section.
Old Aug 6, 2004 | 07:12 PM
Autoworker's Avatar
Autoworker
It's an easy install... get the car up high enough to work comfortably. Corsa recommends renting or buying a exaust tubing cutter. Got mine at Advance Auto. They supply all gaskets and hardware. You'll also need a torque wrench to torque the band clamps and exaust bolts.
Old Aug 8, 2004 | 02:31 AM
[ Ls1 ]'s Avatar
[ Ls1 ]
thanks for your input
To corsa x pipe
