402 short blocks for under $3500.
Old Aug 6, 2004 | 09:26 PM
tbyrne's Avatar
tbyrne
From: Westport, MA. www.tbyrnemotorsports.com - 1-877-4-TBYRNE
St. Jude Donor '06-'07
Default 402 short blocks for under $3500.
SLP will soon have very affordable 402 short blocks ready to ship with no core required!
Crate-Engine-Assembly, "ZL-402" LS1 Short Block (High Compression)
With GM’s versatile "Gen III" small-block gaining popularity as the foundation for a wide range of high-performance engine build-ups, market demand for an affordable LS1 stroker package has become increasingly intense. In response, SLP Performance Parts has devised a revolutionary new Gen III stroker short-block assembly, one that offers unexcelled performance and durability at a truly accessible price.
Dubbed the "ZL-402" to reflect its beastly 402-cubic-inch displacement, the package is chockablock with such race-proven hardware as a new GM LQ9 block, a 4.00" forged steel crank, and 4.00" forged aluminum pistons. With the right cam and heads and a properly tuned PCM, the ZL-402 is fully capable of producing over 575 hp and a similar amount of torque in naturally aspirated form.
This package is sold only in short-block form, minus manifolds, camshaft, oil pump, and other ancillary equipment. The obvious advantage of this approach is that it allows each customer to formulate a parts combination that is perfectly suited to his or her needs. (For those who prefer "one-stop shopping," SLP offers a host of uninstalled options on an à la carte basis.)
Although designed primarily for use in late-model F-Bodies and Corvettes, the ZL-402 also makes a superlative choice for most street-rod, muscle-car, and truck applications. Best of all, it’s sold outright, eliminating the shipping hassles, protracted vehicle downtime, and additional out-of-pocket expenses associated with core returns.
Features
Built entirely from brand-new parts.
Sold outright*no cores required!
GM LQ9 iron 6.0-liter block (includes block plugs)
4.000" 4340 forged steel crankshaft, balanced to rotating assembly
4.000" 2618 forged alloy pistons (includes new rings and full-float pins)
402-CID displacement
6.125" I-beam rods
Includes new, factory-installed cam, rod, and main bearings.
11.3:1 compression ratio (nominal; ultimate compression ratio will depend upon heads and gaskets used)
Designed for naturally aspirated applications
Meticulously assembled to OEM tolerances and specifications.
Oil pump, timing chain, camshaft, pans, plates, and covers not included.
Looking for less compression? There will also be a 9:1 version available!
More details for each of these can be found on our website. We're currently taking pre-orders to provide you with one of the first that become available. They are expected to start shipping around September 1st! Our price is $3499.99 for each with NO core exchange required!
Old Aug 6, 2004 | 10:38 PM
90 droptop's Avatar
90 droptop
When I called them last month, nobody could tell me who's crank and rods they were going to use. Any idea????
Old Aug 6, 2004 | 10:52 PM
tbyrne's Avatar
tbyrne
Good question! I'm going to see if I can get some more detailed specs on Monday.
Old Aug 6, 2004 | 11:36 PM
MiamiDave's Avatar
MiamiDave
How much boost can the 9.1 take...?
T_Vert's Avatar
T_Vert
also what material are the rods made from?
Dave
Old Aug 7, 2004 | 08:13 AM
MiamiDave's Avatar
MiamiDave
Ttt :d
Old Aug 7, 2004 | 08:29 AM
kromberg's Avatar
kromberg
I really do not like the idea of the motor being externall balanced Makes upgrades to clutches and crank pullies impossible.
Keith
Old Aug 9, 2004 | 09:07 AM
MiamiDave's Avatar
MiamiDave
Keith
What are standard LS1's...?
Old Aug 9, 2004 | 09:44 AM
ragtopws6's Avatar
ragtopws6
Keith
Where did you get this information? All the LSX series engines are internally balanced. You know something the rest of us don't know?
Old Aug 9, 2004 | 12:02 PM
kromberg's Avatar
kromberg
I know that 'normal' LSx based motors are internally balanced. If one checks the SLP website, you will see that these motors are externally balanced.
Keith
Old Aug 9, 2004 | 12:28 PM
RonnieW's Avatar
RonnieW
I don't like that they "are designed for N/A applications".
Old Aug 9, 2004 | 12:33 PM
ragtopws6's Avatar
ragtopws6
Keith
Damn, that does suck!
Old Aug 9, 2004 | 05:25 PM
MiamiDave's Avatar
MiamiDave
Old Aug 9, 2004 | 06:08 PM
Pitch Black Z's Avatar
Pitch Black Z
they are internally balanced
Brian Reese posted it on LS1tech.
Old Aug 9, 2004 | 07:25 PM
MiamiDave's Avatar
MiamiDave
Double *****!! They're iron blocks!!
Old Aug 9, 2004 | 07:59 PM
tbyrne's Avatar
tbyrne
Here are some more details -
Production 6.0 block
Internally balanced rotating assembly
SLP sped'd Eagle 4" crankshaft
SLP spec'd 4" pistons, 2618 forging (Ross or Manley). N/A version - approx - 1.2:1. Heavy duty forced induction version approx 9:1. Compression ratios are nominal, ultimate compression ratio wil depend on the heads and gaskets that are used.
Assembly is meticulously assembled to OEM tolerances and specifications.
Oil pump, timing chain, camshaft, pans, plates and covers not included.
Old Aug 9, 2004 | 08:03 PM
juiced's Avatar
juiced
Are there going to be any options for pistons with valve reliefs on this package? Or am i just going to have to get them flycut
To 402 short blocks for under $3500.
Old Aug 13, 2004 | 10:44 AM
tbyrne's Avatar
tbyrne
I'm not showing that there will be any other piston options available.
Old Aug 13, 2004 | 11:28 AM
MiamiDave's Avatar
MiamiDave
Will any be made in aluminum...?
Old Aug 13, 2004 | 11:32 AM
Dicecal's Avatar
Dicecal
Iron Block?..NO THANKS!
