Oil temp sensor
Old Aug 7, 2004 | 09:15 PM
Blow Torch's Avatar
Blow Torch
Default Oil temp sensor
Where is the oil temp sensor located?
Old Aug 8, 2004 | 08:07 AM
Blow Torch's Avatar
Blow Torch
Ttt
Old Aug 8, 2004 | 09:17 AM
RCK1999's Avatar
RCK1999
It's on the top of the block behind the intake. You need to move the intake about 6" forward in order to gain enough access to replace it.
If you do a search on this forum, other posts will include lots of detail and drawings from the shop manual.
Old Aug 8, 2004 | 12:46 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
On the 02 Z06 it is just above the oil filter on the driver's side lower rear of the motor. I believe it is here on all LS1/LS6 motors. Easy to get to from the bottom. It is a little oval attachment held on by two small bolts with a wire going into it.
This is where most remote oil cooler line adapter blocks tap into.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Aug 8, 2004 | 05:08 PM
Blow Torch's Avatar
Blow Torch
I am not getting a reading from the sensor (low oil temp all the time) and I am assuming that I either left it disconnected, or knocked it loose while doing some work on the car. Now the question is whether I did it while installing the headers, or putting on the new intake?
I did a search, but didn't really find any relevent information, especially concerning it's location.
Old Aug 8, 2004 | 05:21 PM
DsC5's Avatar
DsC5
I've got the same problem.
Old Aug 8, 2004 | 05:41 PM
C66 Racing's Avatar
C66 Racing
Might have melted it with the new headers as well. Find the line and trace it out to make sure it is away from anything hot. I wrapped heat shield around my electrical lines there for this reason. Hopefully it is just something simple like being unplugged.
Old Aug 8, 2004 | 06:49 PM
RCK1999's Avatar
RCK1999
Whoops, I was thinking oil pressure.
Old Aug 8, 2004 | 08:10 PM
C66 Racing's Avatar
C66 Racing
That's what I thought, but wasn't positive. I haven't taken that one out yet, but know where it plugs in.
Old Aug 8, 2004 | 08:58 PM
Blow Torch's Avatar
Blow Torch
Thanks for the help guys
To Oil temp sensor
