Shift Knob replacement ???
Old Aug 8, 2004 | 07:56 PM
Neatnic's Avatar
Neatnic
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '07-'09
Default Shift **** replacement ???
I want to replace the factory (auto) shift handle with a aftermarket one. I know there was a thread with step by step instructions. Does anyone have that or now how to remove and replace the handle.
Old Aug 8, 2004 | 08:30 PM
yelloyello's Avatar
yelloyello
CI 6-7, 9-10 Veteran
Look on the VetteEssentials website. Great instructions for many tasks. There is only a 2 pronged pin holding it in place. It is located on the portion that faces the dash. Use a tiny flat head screwdriver and wedge it out. Good luck
Old Aug 8, 2004 | 09:56 PM
SteveL2's Avatar
SteveL2
Here's the link he's referring to, in case you're not familiar with Vette Essentials: http://www.vetteessentials.com/instr...t_install.html
If you're just changing the ****, you need only do steps 4a and 4b.
To Shift Knob replacement ???
