Bump Steer Solutions?
Old Aug 10, 2004 | 06:03 PM
Matt69-ZO6's Avatar
Matt69-ZO6
Default Bump Steer Solutions?
After lowering the car (bushings cut and longer rear bolts), the bump steer in the car is a bit more noticeable, tolerable, but noticeable.
Has anyone had a sucessful solution? Bump steer rods? Coilovers? What about '04 shocks?
Not really a serious issue, but just been thinkin' about it...
Old Aug 10, 2004 | 06:23 PM
XPC5R's Avatar
XPC5R
If it is true bumpsteer/toe change you are fighting, Baer makes a bump steer kit that replaces the outer tie rods with rod ends and adjustable spacers.
http://www.baer.com/Products/BaerTracker.aspx
I've seen these on LGM's world challenge cars, so that should be a good source.
You may just have worn tie rod ends or wheel bearings, or both. They all feel similar, wandering, bump steer. They seem to go out very early if the car is used hard.
Old Aug 11, 2004 | 01:29 PM
Matt69-ZO6's Avatar
Matt69-ZO6
What are you trying to say about me?
Old Aug 11, 2004 | 03:26 PM
XPC5R's Avatar
XPC5R
sounds like you know...
Old Aug 11, 2004 | 03:42 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
get wider tires on the front
To Bump Steer Solutions?
