Z51 suspension questions
Old Aug 11, 2004 | 11:32 AM
KapUSMC's Avatar
KapUSMC
Default Z51 suspension questions
Hey all,
My 99 FRC shocks are starting to get worn, so Im looking into suspension upgrades when I do it. If I went with something like the Bilstien sport shocks, should I upgrade the sways at the same time? It handles pretty good now, but Im just trying to see if springs/sways are worth the price of the swap if you already have the z51.
Almost forgot... I do drag the car occasionally, I have yet to AutoX/road course it, however Im sure I eventually will. However for the most part, the car is driven normally, but will see some limited non-competition track use. Thanks,
Kap
Old Aug 11, 2004 | 12:20 PM
BigJoe's Avatar
BigJoe
If you have the base suspension going to Z51 (or even better Z06) bars and springs is definately worth it. If you already have Z51 going to Z06 will not buy you much. Of course you could always go from Z51 to a racing suspension but those are pricy and a bit harsh in normal driving.
Old Aug 11, 2004 | 05:21 PM
mountainbiker2's Avatar
mountainbiker2
I put on 04 Z06 shocks. Much better over bumps when racing around corners. Smooth corners makes no difference. I like the stock sway-bars. Good balance. The car is stiffer with those shocks. I have a 99FRC too.
Old Aug 11, 2004 | 05:55 PM
VetteDrmr's Avatar
VetteDrmr
Leave the Z51 stuff alone, the Bilsteins are a bit stiffer, but they won't necessarily make it handle any better than Z51 shocks. '04 Z06 shocks are the rage right now, so look into those as well. I have no idea how they compare to Z51 in ride quality, no one mentions that.
HTH, and have a good one,
Mike
Old Aug 11, 2004 | 06:26 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
I'm going to disagree with that. Went to the Z06 springs and sways with a bilstein sports. Made a huge difference over the Z51. Car now feels stable at high speeds, and feels better through mid range corners 60-80 mph.
Old Aug 11, 2004 | 06:43 PM
Vince99FRC's Avatar
Vince99FRC
Very interesting post. I also have a 99 FRC and the car handles great right now compared to my F-body with eibach pro-kit and revalved bilsteins. I purchased some BMR sway bars and plan to purchase some 04 Z06 shocks if my current shocks cant take the pounding of my new iron block going in. I have chased a few local Z06 guys around corners and it seems only due to horsepower they were able to slowly pull away. I think the 99/00 FRC's are a good bang for the buck and it only takes a few minor upgrades to get Z06 handling. Just looking back at my 01 SS with upgraded suspension including S/T 35mm sway and stock 19 mm sway in the rear. I was able to keep up with Z06's on local corners on the highway, but the fear of the rear coming around was always there. I can honestly say with the C5 you do not worry about that as much. Oh.. My old SS made crazy power so horsepower was not an issue.
Old Aug 11, 2004 | 06:52 PM
LoneStarFRC's Avatar
LoneStarFRC
ALL FRC's came with the Z51 suspension. To change to the Z set-up entails just changing the rear spring, (as the front is the same as the Z already), changing anti-roll bars and adding the '04 shocks. These changes will make a very noticeable difference in the cornering and handling department, etc but maybe only marginal in the drag racing area. These mods are not too expensive though, so if your looking to auto-x or for more of a flatter cornering ability, then go for it!
Robert
Old Aug 11, 2004 | 08:33 PM
KapUSMC's Avatar
KapUSMC
Actually all the 99 FRC's had the Z51. Was an option in '00. But so yea, I currently have z51.. I know I need new shocks.. Just wasnt sure if sways were really gonna make enough of a difference to justify the cash.
Old Aug 11, 2004 | 09:36 PM
LoneStarFRC
When I changed over to the Z's anti-roll bars I noticed a nice difference. Of course getting rid of the run-craps was in itself a major improvement.
Old Aug 11, 2004 | 09:47 PM
Vince99FRC's Avatar
Vince99FRC
I think you will notice a big difference between the Z06 sways and the 99 FRC Z51 setup.. You ask why? According to GM the 99 FRC front sway bars were 25.4mm and the rear were 21.7mm. The 00 FRC's front sway bars were 28.6mm and the rear were 23.6mm. The Z06 sway bars are 30.0mm in the front and 23.6mm in the rear. You cant tell me going from 25.4mm to 30mm in the front and from 21.7mm to 23.6mm in the rear will not be noticeable.
Old Aug 11, 2004 | 09:56 PM
VetteDrmr's Avatar
VetteDrmr
Originally Posted by KapUSMC
Actually all the 99 FRC's had the Z51. Was an option in '00. ...
Sorry, but Z51 was standard on all FRCs. GM just decided to give everyone headaches by listing Z51 on some RPO code sheets, on others just the FE2 (I think) suspension, and both on others.
And, I'll have to go against the significant differences everyone's seeing between Z51 and Z06 suspension. I think that folks see a difference going from a used Z51 suspension (shocks and bushings, mainly) and new Z06 suspension parts.
And, if what we're talking about is feel, hey, that's great! What I think about is the actual cornering ability of the car.
Have a good one,
Mike
Old Aug 11, 2004 | 10:00 PM
Vince99FRC's Avatar
Vince99FRC
Have a good one,
Mike
No doubt new suspension parts are going to feel better than used or worn suspension parts. I also think the diameter of the sway bars and stiffer shocks play a roll as well.
Old Aug 11, 2004 | 11:44 PM
KapUSMC's Avatar
KapUSMC
Vince, thanks for the diameters... I didnt realize the difference in sway sizes between 99 and 00 was that big.
Old Aug 12, 2004 | 03:20 PM
Vince99FRC's Avatar
Vince99FRC
A local Z06 owner brought this to my attention and I decided to investigate. I decided to go with the bmr setup. 32mm solid front and 19mm solid rear. I think coupled with 04 Z06 shocks that should help me perform like a Z06..
Old Aug 12, 2004 | 09:56 PM
mountainbiker2
I think it will be noticeable with more front end understeer. The difference between the front and rear size are much more with the Z06 sways. The Z06 has a stiffer rear spring which would make that end slide more. So GM put on a fatter swaybar in the front to compensate for that.
Old Aug 13, 2004 | 02:45 AM
Vince99FRC's Avatar
Vince99FRC
I agree
To Z51 suspension questions
