what does the intake gasket look like, and...
Old Aug 13, 2004 | 11:41 AM
MonteHall's Avatar
MonteHall
Cruise-In VII Veteran
St. Donor '03 & '06
Default what does the intake gasket look like, and...
is it reusealbe?
I'm going to fix my oil sensor this weekend.
Old Aug 13, 2004 | 11:56 AM
Patches's Avatar
Patches
There are actually 8 individual "gaskets" for the intake manifold - one around each port. They look similar to the valve cover gaskets in that they resemble sort of an o-ring type of setup. A set of 8 is about $55 fro your dealer. They are reusable though, so you only need to replace them if you find damage or they are permanently compressed to the point where they leak.
Old Aug 13, 2004 | 11:59 AM
FreddyG's Avatar
FreddyG
Yas, they are reusable. They are o-rings that are fit into each intake port. just be sure to give them a look over, before putting the intake back on. You don't have to pull the rings out, but visually look for cracks, or split o-rings.Good Luck!
Here's a pic( Courtesy of JMX's EXCELLENT site):
Intake pic
To what does the intake gasket look like, and...
