Water wetter...
Old Aug 13, 2004 | 08:53 PM
stano's Avatar
stano
Default Water wetter...
Anyone use this to cool down your coolant temps and if so, does it work??
Thanks and
Old Aug 13, 2004 | 09:57 PM
scott_fx's Avatar
scott_fx
Thanks and
A lot of the rx-7 guys use it because of the extreamely hot running rotary engine. They say it works well, though I havent had any first hand experience. You could try looking around the rx7 forum
`s
Old Aug 13, 2004 | 10:20 PM
rws.1's Avatar
rws.1
I use Redline waterwetter in my C4, temperatures dropped over 20 degrees to mid 170's after use.
Old Aug 13, 2004 | 10:29 PM
jfrc's Avatar
jfrc
We could not run our sportbikes on the track with radiator fluid- if spilt it leaves the track surface too slick. Everyone said run distilled water and Red line water wetter- it worked. If it got hot from idling in TX heat or traffic, it actually cooled down quicker.
Old Aug 13, 2004 | 10:42 PM
CRAIGVETTE's Avatar
CRAIGVETTE
Veteran: Coast Guard
Senior Member
Cruise-In V Veteran
I use distilled water and Water Wetter and it lowered my temps by about 10-15 degrees.
Old Aug 13, 2004 | 11:42 PM
Threed's Avatar
Threed
From: GOCC - Rebels Without A Clue Santa Barbara, CA
Stan we use to use it in the race car. I never saw any cooler temps but it was a legal additive. They don't want anti freeze because of it's slick properties when puked out on the track.
By the way you have mail...
Old Aug 14, 2004 | 12:05 AM
Rolm's Avatar
Rolm
A big waste of money. you would be better off to pee in your rad at leased you will save $$$$
Old Aug 14, 2004 | 12:22 AM
stano's Avatar
stano
ouch
Old Aug 14, 2004 | 12:31 AM
stano's Avatar
stano
Can I add the Red Line Water Wetter to my current coolant???
Thanks guys!
Old Aug 14, 2004 | 12:44 AM
b_pappy's Avatar
b_pappy
From: the GOCC are everywhere, even back from "band camp"
Stano,
long time no see...yes, water wetter is compatible with your water and anti-freeze. I run it in the Nomad. Can't say it helps, but the Nomad doesn't overheat either. From what I've read it is more effective with straight water (distilled preferred). Good luck and drop me a line, let me know what you've been up to.
Bruce
Old Aug 14, 2004 | 12:52 AM
stano's Avatar
stano
Originally Posted by b_pappy
Stano,
Bruce
Thanks Bruce and I'll be in touch
Old Aug 14, 2004 | 02:24 AM
BHP's Avatar
BHP
Works if you are running just water.
Old Aug 14, 2004 | 02:48 AM
Shylor's Avatar
Shylor
Well at "least" a beer drinker would have an endless supply of coolant then.
Old Aug 14, 2004 | 12:28 PM
Ls1Rat's Avatar
Ls1Rat
it's a water pump lube only, don't believe the
Old Aug 14, 2004 | 07:40 PM
CRAIGVETTE's Avatar
CRAIGVETTE
Senior Member
Cruise-In V Veteran
That is incorrect. It breaks the surface tension of water, preventing it from "sticking" so to speak to the internal engine passages, thereby flowing more effiecently and in turn removing heat better. There was a great post on the stuff about a year back, but all I know is that it works. It is not my imagination that my temps dropped.
Old Aug 14, 2004 | 08:40 PM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
Originally Posted by Craig2000
It breaks the surface tension of water.
Soap does the same thing, but I wouldn't put it in my radiator.
Old Aug 14, 2004 | 09:47 PM
Ls1Rat's Avatar
Ls1Rat
do you sell the stuff ?
To Water wetter...
Old Aug 14, 2004 | 11:03 PM
Andy@A&ACorvette's Avatar
Andy@A&ACorvette
Platinum Supporting Vendor
40 Below by Pro Blend works much better. I've used it for years.
The new Evans water pump and their special waterless coolant is supposed to work well too. I'm just starting to experiment with that.
I fit Spal fans into the stock shrouds on my big motors. They REALLY pull some air. It takes a little fabrication but they will fit.
__________________
PLEASE TAKE A MOMENT TO VISIT OUR WEBSITE AT WWW.AACORVETTE.COM
NOW PARTNERING WITH AFFIRM TO OFFER INTEREST FREE FINANCING!
ANDY GREEN- OWNER/ CEO -A&A CORVETTE / A&A SUPERCHARGERS
477 LAMBERT ST
OXNARD CA 93036
WWW.AACorvette.com
A&A CORVETTE SUPERCHARGER SYSTEMS
HOME OF THE WORLDS FIRST
CENTRIFUGALLY SUPERCHARGED C7
SUPERIOR ENGINEERING- SUPERIOR POWER
SUPERIOR PRICING- SUPERIOR CUSTOMER SUPPORT
Andy@AACorvette.com 805- 278 4107
Old Aug 14, 2004 | 11:49 PM
comp's Avatar
comp
it's a water softener...... thats how it works, use distilled and your coolant, if that doesn't do it there are other problems in the system
Old Aug 14, 2004 | 11:52 PM
comp's Avatar
comp
iv'e tryed to find a better coolant than "pure water" haven't found
anything better ,,,,that didn't still have water as a base stock
