From: Edmond, OK...One of the first rules of online forums: If you don't like what is said but can't refute it, attack the poster.
I don't know the answer to your question yet. I ordered my Z06 sway bars a couple of days ago and should get them in about a week. I'll probably put them on next weekend. Then I'll post the results. It looks like a pretty easy swap.
Jeff
Maybe someone who has already put on Z06 swaybars will chime in.
Personaly, I don't want to get a harsher ride from the Z06 shocks, the ride on lowered stock bolts and stock shocks is just about right for me. But I do want to eliminate some of the body roll and the Z06 swaybars would seem to be the right solution.
Looking to replace stock bars with Z06 sway bars. Can anyone tell if this mod will noticeabley decrease body roll while cornering?
Thanks!
Night and Day! I just swapped my stockers out for a set of Z06 bars and the car corners as flat as I would expect a Corvette should. Straight line, the car still rides comfortably but it corners like it's on rails now. I'm looking to stiffen the springs to Z51 to tighten the performance up a little more. The Z51 rear spring is in between the stiffness of the Z06 and stock. Over 120mph the stock setup is too soft IMO. I say you will notice the difference as soon as turn the first corner. You may find a used set on ebay for cheap. The Z51 front bar on 2000+ models is the same as the Z06 and you may get them cheaper still.
I have it on my 99 FRC and it was the best bang for the buck suspension mod ever. Best thing is you can pick a set up for less than $200 used. This is definately must do for base or Z51 set up.
Actually one of the reasons I went with the Hotchkis kit was because it included metal end links and new bushings in the package (in addition to being stiffer than the Z06). I'd suggest changing to metal end links.
I recently replaced my Z51 front bar with a ZO6 bar, and I upgraded the endlinks to the aluminum end links. It definitely made a difference!
I installed myself and followed the instructions on www.ls1howto.com
It's a very good bang for the buck mod.
Thanks for the good info, Boo!
I bought the Z06 stab kit from Fred Beans for 231.99 shipped. It consists of:
||--Genuine GM Z06 Stabilizer Bar Kit--||
10419094 - Front Stabilizer Bar
10424743 - Rear Stabilizer Bar
(2) 10351954 - Front End Links
(2) 10351954 - Rear End Links
(2) 10419095 - Front Bar Insulators
(2) 10333410 - Rear Bar Insulators
i just did my 99 vert 66,000 mi to new z06/metal ends sways, gmpartsdirect for $186+
and new bilstein sports, standard $300.
left the stock springs, these are what makes the ride, the other parts control the ride. imho.
and lowered it the 1" or so on the stock bolts. had it aligned and now its right along side of perfect. the handling and ride comfort are fantastic for a convertable sports car.
