rear sway bar in C5
Old Aug 16, 2004 | 01:37 PM
CamSS00's Avatar
CamSS00
2nd Gear
Default rear sway bar in C5
I need to find out what mm sway is in the rear. It has the F55. Cause when I go to order it askes for a 19 or 22 mm.
Old Aug 16, 2004 | 10:43 PM
CamSS00's Avatar
CamSS00
2nd Gear
anyone?? I guess I'll have to measure then.
Old Aug 17, 2004 | 12:08 AM
jl240z's Avatar
jl240z
Contact gene culley at Fred Beans or ken fitchner, both are vendors on the forum and would probably have the info you need plus their prices are better than dealers give. Good luck
Old Aug 17, 2004 | 02:01 AM
Ls1Rat's Avatar
Ls1Rat
TAKE A 3/4 inch or 19mm wrench and slide it over the bar.
If it fits, it's 19 mm.
If it doesn't it's a a 22mm.
To rear sway bar in C5
