Help me solve my cooling problem
Within 30 minutes of around-town cruising with the AC on full my coolant temps got up to 240 degrees and some of my coolant (which was heavier on the water side than on the coolant side) boiled out of reservoir. The ambient temp was about 100 degrees F and I think my coolant would have gotten hotter but I turned off the car after noticing that it was losing coolant. I topped off the car with 50/50 and proceeded to the rest of my experiment: cruising around for a while with no AC to see where my temps would get to. I managed to get the coolant up to 210 degrees. All of this is being done with a 160 thermostat and the fan turn on temps set to 180 and 185. The radiator is also lowered to accomodate my supercharger.
I'm trying to get some troubleshooting tips to determine exactly where my problem lies. I've checked both of my fans and they both turn on. They seem to be pushing quite a bit of air too. I swapped out my stock radiator with a Dewitt's radiator (almost twice as big) and I still have the heating issue (it just takes longer to heat up due to the increased coolant capacity). I've also tried the obvious which is checking the condensor and radiator for debris and pressure washing it to remove any dirt that may have accumulated -- no dice on that. I do have my center air dam in place but the side air dams were removed to help the car clear ramps and lifts. I am also running the Z06 screens with the fog light surrounds removed to improve under-the-hood cooling.
Is it somehow possible that the fans are not pushing as hard as they should? Are there other high-powered alternatives out there that would move more CFMs than the stock fans but fit in the stock fan assembly? Are there other things I should look out for or check? None of my coolant hoses appear to be kinked.
Help!
Good luck...Bill
Good luck...Bill
but before you pull the thermostat use a piece of paper behind each fan to make sure they are actually operating
DrCoffee, I have been thinking about getting a Mezierre. The only things I'm not a big fan of is (a) the price and (b) the fact that now my water pump would have a more finite lifespan than it used to. Still, if it solves my problem, I'll be a happy customer.
Any other thoughts/suggestions?
My car runs at 195 with a 192 t-stat in 108 degree weather at 20 to 95 mph.
I'd check :
See if it's tuned correctly , it maybe running lean.
bad t-stat
restricted exhaust
bad head gasket
I'd post in here also : http://forums.corvetteforum.com/forumdisplay.php?f=86
The fact that it takes longer to heat up the car now tends to make me believe that the radiator works just fine. On top of that at highway speeds the fans are factored out. You did not say how many miles are on the car. It may be that the water pump is not working properly. Does it get hot at crusing speeds on the freeway? If not it may be the fans.
Is it possible that somewhere within the engine the flow of water is being restricted?
If I were you I would replace the water pump at this point. I would also drain the system and flush the engines (not the radiator) cooling system in the reverse direction. Normally distilled water is used in the cooling system, are you using that? If it came down to it I would use a garden hose to reverse flush the engine if I had to.
Its easy to check airflow, just look for obstructions, besides if you recently put the Dewitts in you had it all apart so you know if airflow is blocked.
If air is moving through the only thing left is coolant. Is it flowing properly? My bet is its not.
All of this assumes (thats dangerious) that the rest of your engine is working properly, as in no head gasket leaks.
I have installed 12" Spal fans in the stock shroud. They pull some SERIOUS air! The Evans high pressure pump and their waterless coolant is supposed to work well too.
You might check to see if you have combustion gasses in the cooling system. (blown or leaking head gasket) That will heat the water up, no matter what size radiator. Good luck with it!
PLEASE TAKE A MOMENT TO VISIT OUR WEBSITE AT WWW.AACORVETTE.COM
NOW PARTNERING WITH AFFIRM TO OFFER INTEREST FREE FINANCING!
ANDY GREEN- OWNER/ CEO -A&A CORVETTE / A&A SUPERCHARGERS
477 LAMBERT ST
OXNARD CA 93036
WWW.AACorvette.com
A&A CORVETTE SUPERCHARGER SYSTEMS
HOME OF THE WORLDS FIRST
CENTRIFUGALLY SUPERCHARGED C7
SUPERIOR ENGINEERING- SUPERIOR POWER
SUPERIOR PRICING- SUPERIOR CUSTOMER SUPPORT
Andy@AACorvette.com 805- 278 4107
I'd check :
bad t-stat
restricted exhaust
bad head gasket
At highway speeds, cruising at 2000RPM or so, my temps are nice and low, even in the hot weather with the AC on high... somewhere around 180ish. This leads me to believe that it could be the fans as was suggested above, but oddly both fans do turn on and they are pushing quite a bit of air out toward the motor. I don't have a frame of reference to say whether or not they're moving air like they should but I was surprised by how much air they moved when I tested the fans using EFILive.
I was actually going to give you a call today but I figured I'd dig around on the forum first before bothering you.
Help!
This may be way too simple but have you checked up in the front of the radiator for debri? It's a great trap for anything that can blow in. I have even seen a plastic shopping bag stuck up there in one car!
