Lately, my fuel gauge has been acting squirrely. It sometimes all of sudden goes from an actual full reading to empty causing my low fuel/reserve fuel indicator to come on. I have no confidence in the reading anymore. What gives??? Whats the fix for this???
My 2000 FRC had the same problem. Whenever the gas gage would read below half full the Low Fuel indicator would suddenly come on the DIC.
I just took it to the Chevy dealer last week for the column lock recall. The technician said that the reprograming for the column lock problem would likely fix the fuel gage problem so they did not charge me. I don't understand how the two are related, but it's working fine. I will continue running the tank down to see when the Low Fuel indicator shows up.
The two are not related, but the software upgrade for the column lock recall apparently includes all other upgrades, and the fuel gage upgrade is one of these.
My 2000 vert did the same thing the day I bought it. The problem was with a defective sending unit in one of the 2 tanks. It's a common problem. There's a Technical Service Bulletin on it as well.
This is not a new issue infact it seems to be the most common glitch in the C5. The consensus is too much sulfur in the gas you are burning. I had the problem the 2nd month I had my 2004. And it coincided with 2 tanks of cheap gas. I checked on the forum and it seems Chevron with techron is the most popular gas of choice. I switched to that. Also a bottle of techron into a low tank of fuel before filling it up once, maybe twice if no change in the problem. And then at every oil change. I did this and no problems since.
I took it to the dealer twice with the same problem in my 2000 and after the second time, about 20k miles ago, it was apparently fixed with no problem. I was told that it was the sending unit.
Same problem here on my '98 Vert. I'm on my second bottle of techron in four tanks. Problem is intermittent. No Chevron stations in my area - is Texaco using the same additives now that I heard they are owned by Chrevron?
So how hard is it to replace the sending unit? Any DIY instructions? My search didn't turn up anything a month or so ago when my problem started.
What is the Gm tech note say? Recall ?
My gauge on my C5 is weird. It'll read right one second and say I'm out of fuel the next. It's really to bad that they do this because when they do read right they are really accurate from what it looks like. My C4 jumps around under a quarter tank from @110 mile range to 40s and back so I have to do an average in my head!
