C-5 TECH/ BILL CURLEE Need Help
Old Aug 16, 2004 | 09:01 PM
GKrenn's Avatar
GKrenn
Default C-5 TECH/ BILL CURLEE Need Help
I'm still getting the TCS code 1214. C-5 Tech, In another thread you mentioned that the EBTCM is basically a cover kit. Can you elaborate on that.
Bill, I've gone over the grounds two or three times and they look good. How do you remove the white tie-wrap that helps secure the large harness on the right side of the EBTCM and how does the connector on the bottom remove. I didn't want to bust anything.
Again, thanks for your assistance.
Old Aug 16, 2004 | 10:28 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
The EBTCM can be removed from the BPMV (part with the brake lines) by removing the 6 torx head screws and the 2 connectors
