whats wrong with my car?
Old Aug 17, 2004 | 08:35 PM
2002Z06Yellow's Avatar
2002Z06Yellow
Default whats wrong with my car?
I just put nitto 555R2s on my car. took it for an easy 10 mile drive before i floored it a couple of times. check engine light came on and these are the codes. i decoded them in english, but now someone should decode them into PROPER english cuz i am mechanically challenged
U1160 Loss of Communications with LDCM
B2265 Horizontal Position Sensor Fault DCM-R
P0803 1-4 Upshift Solenoid Control Circuit (M/T) -B
i think the P0803 code wouldnt reset.
does it have to go to the dealer? i hope there is something i can do.
btw i noticed something getting lose the past couple of days could that be it?
thanks
Old Aug 18, 2004 | 07:24 AM
wrustywrench's Avatar
wrustywrench
I wouldnt worry about the ldcm cosde,, its the left door control module,,,I get the same one after I use the top down tech,, some say the module is going bad,, but it has still been working after a year,,,always a history code,,the othere, i dont know nuthin about
Old Aug 18, 2004 | 06:05 PM
wwashing's Avatar
wwashing
thanks
Are the tires the same size as the stock tires? If you have changed the diameter of your tires you could be causing the computer to be confused?
Old Aug 18, 2004 | 06:16 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Do you have a CAGS bypass on your car, the cause of the P0803 code could be cause by a bad cags solenoid or if the resistor in the bypass is bad
Old Aug 18, 2004 | 06:25 PM
Richin Chicago's Avatar
Richin Chicago
thanks
None of these have anyhting to do with the tire install or the handlingof your car:
U1160 is quite common and is of no concern as long as it has an "H" (history)
B2265 is a postion sensor for the right mirror to track with your memory seat.
P0803 means your skip shift elimnator came undone or the resistor burned out if you have a skip shift eliminator installed.
To whats wrong with my car?
