"Pull key" message after CLB install
Old Aug 18, 2004 | 02:09 PM
dmtnt's Avatar
dmtnt
St. Jude Donor '03-'05-'06 & '12
Default "Pull key" message after CLB install
I've heard of this happening on 97-99's but never on an '02. Just installed the COH CLB and the first time I went to start it, got the "pull key wait 10 seconds" message. Did so and it didn't return; car started fine. Anyone else experience this? Has it reoccurred?
Edit: never mind, was just informed of the "pull fuse" fix for this. Should've read the damn instructions!
Old Aug 18, 2004 | 07:07 PM
Cocked and Locked's Avatar
Cocked and Locked
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
I got the "pull key" message at the dealership the first time I started mine after the column lock recall was performed. Never happened again in the two weeks since.
Old Aug 19, 2004 | 05:24 PM
Quasar21's Avatar
Quasar21
Where physically is this fuse located? I'm assuming you're referring to the fuse #25. Are they identified by number in the owner's manual? (He said before going all the way downstairs to check for himself )
To "Pull key" message after CLB install
