NOISY front suspesion
Noisy front swaybar bushings are a common problem. Is it maybe a creaking sound?? Like a creaking door or creaking mattress??
Happen mostly at slow speeds..... lots of times over speedbumps?? This is likely the bushings. Easy to fix.Does the noise occur at cruise speeds on the highway?? Does it make the noise on the highway when you quickly change from lane to lane?? There are lots of fasteners associated with the front suspension that may need to be torqued and can make noise. Also the swaybar endlinks can get loose or broken.
The rubber bumpers for the hood can make a pop noise, mostly noticeable when backing up. This is easy to fix.
Try to explain the noise better and give examples of exactly when you hear the sound.
Sometimes the rubber stops (four of them) for the hood will cause a creak if they are not lubed; a little grease does the job there. You can purchase new bushings and replace them, but its not necessary and you will probably get the noise back. The problem lies with dirt and moisture getting into the polyester sleeves. The bushings are cheap ($6 each) and it won't hurt to replace them, but make sure you completely clean the sway bar of all contamination before reinstalling. I've found the torque rating for the bolts has nothing to do with the noise, but its important so you don't strip out the aluminum threads. I believe the torque rating is 40-45ftlbs.... I go with 40. Check a service manual to make 100% sure of the correct torque.
The solution I've used is to clean the bar AND the bushing. I used dawn liquid to soak the bushing and then completely dry it. The trick is to coat the inside of the bushing with silicone grease. Any other grease or lube will only last a short time and the problem will come back. I last did mine over 1 year ago and no noise. On new bushings, I would install dry and see how long they go. When they do start making the noise, then you can try the silicone. On old bushings, you must coat them..... cleaning alone won't work. The bushings are easy to repair/replace, just make sure you observe how they fit into the bracket, as they only go 1 way.
While your under the car, its not a bad idea to take a torque wrench AND a Service Manual and check the torque of all the suspension fasteners.
The solution I've used is to clean the bar AND the bushing. I used dawn liquid to soak the bushing and then completely dry it. The trick is to coat the inside of the bushing with silicone grease. Any other grease or lube will only last a short time and the problem will come back. I last did mine over 1 year ago and no noise. On new bushings, I would install dry and see how long they go. I installed these dry and with the new ones, I will be using a synthetic grease. When they do start making the noise, then you can try the silicone. On old bushings, you must coat them..... cleaning alone won't work. The bushings are easy to repair/replace, just make sure you observe how they fit into the bracket, as they only go 1 way.
While your under the car, its not a bad idea to take a torque wrench AND a Service Manual and check the torque of all the suspension fasteners. I checked every bolt, nut, weld, all of the suspension pieces and nothing looks amiss or loose. I hope the new, greased bushings does the trick.
