Are Headers reliable for the long term?
Old Aug 23, 2004 | 07:46 AM
Alex1217's Avatar
Alex1217
St. Jude Donor '08-'09
Default Are Headers reliable for the long term?
Just curious, do headers like kooks or LG's long tube headers last as long as factory setup or are they more prone to cracking over the years. What's the warranty on kooks and LGs? Will they basically last for the life of the engine like the stock setup?
Old Aug 23, 2004 | 08:31 AM
L.Lopez's Avatar
L.Lopez
I don't now the warranty on the headers but I could tell you to stick with stainless steel headers.I've seen steel headers rust within a year.And I've also seen steel header crack by the EGR tubes and by the brackets that hold them to the bellhousing.
Good Luck!!!
LEE
Old Aug 23, 2004 | 09:20 AM
grsz06's Avatar
grsz06
Kooks Longtubes!!! All stainless and loads of HP!!
Old Aug 23, 2004 | 01:45 PM
Alex1217's Avatar
Alex1217
That's what I'm planning to get. She'll probably see some agressive autcrossing once or twice a year at most, and of course the occassional WOT takeoff.
Old Aug 23, 2004 | 05:24 PM
see5's Avatar
see5
Stainless Works are good for life
Old Aug 23, 2004 | 05:29 PM
MikeJamesC5's Avatar
MikeJamesC5
So did Kooks come out with an all stainless x-pipe now? Because last I heard from Cartek they said Kooks x-pipe is not stainless. I would go with LG LT's. They are all stainless.
Old Aug 23, 2004 | 06:06 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
You will have NO problems with LGM headers
Old Aug 23, 2004 | 07:13 PM
Matt @ LG Motorsports's Avatar
0Matt @ LG Motorsports
Former Vendor
LG Pro Long Tubes are all 304 stainless steel and have no longevity issues
Old Aug 23, 2004 | 07:35 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
Just got the Kooks from the UPS man today and they go on this week hopefully.
As they are 304 stainless, I don't worry about the headers. the x pipe is not 304 but neither was the stock setup to my knowledge. My Corsas are stainless, but mufflers can and do go bad.
Old Aug 23, 2004 | 08:03 PM
CJS's Avatar
CJS
FLP's for about 2 years and 11,000 miles, no problems except I have to retorgue the bolts every so often.
Old Aug 25, 2004 | 11:26 PM
2KREDVert's Avatar
2KREDVert
Headers rust from the inside out so you are not seeing anything YET. Yes, stainless rusts too. Best thing to do is get them coated at Jet Hot or similar place. Then, they will last the life of the car. The coating will also carry the heat out the exhaust for better scavanging and lower under hood temperatures.
Old Aug 25, 2004 | 11:32 PM
colbachlaw's Avatar
colbachlaw
LGs are great.
I have had a ton of headers on my previous vettes and they all have had problems.
You get what you pay for and I have zero complaints about my LGs have been problem free.
buy them, you will not regre it
Mike
Old Aug 26, 2004 | 03:15 AM
EFI-1's Avatar
EFI-1
That was the main reason I went with the LG's......don't like the idea of everything not being stainless.
Old Aug 26, 2004 | 08:25 AM
Alex1217's Avatar
Alex1217
So what's the down pipes on the kooks made out of? Aluminum? Iron? I know the headers themselves are stainless steel but I'm thinking everything from the cats back might be aluminum. Does that mean that the kooks setup is slightly lighter than the LGs? Also, If the stock setup is iron, how come they don't have any rusting issue? (that I know of anyway).
Old Aug 26, 2004 | 11:42 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
This may or may not be relevant, however here goes... I had a set of Edelbrock headers and y-pipe on a Firebird a number of years ago. Had the pipes coated by Swaintech. They were on the car 9 years before I sold it, and were still on the car for a year or two afterward, as far as I know. As someone said, however, you have to check the bolts now and again.
Old Aug 26, 2004 | 12:13 PM
Jackal's Avatar
Jackal
If you have a regular steel set of headers coated correctly they should last just as long as any SS set. The stock manfolds are SS if a really low grade of SS.
To Are Headers reliable for the long term?
